cant get python 413 into program mode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129842
Printed Date: June 03, 2024 at 9:31 AM
Topic: cant get python 413 into program mode
Posted By: overfloater
Subject: cant get python 413 into program mode
Date Posted: December 24, 2011 at 9:00 PM
Hi guys,
I have been all over this site and love it. Its very helpful and I appreciate it.
Anyway, as the title indicates I can't seem to get a Python 413 RS to go into program mode. I installed it with the wiring connections listed on this site in a 2008 Hyundai Santa Fe (US) and everything works great. The doors lock/unlock and remote start work perfectly.
I need to change some options in the menu. I turned ignition to run and then off then held the program button but nothing happens.
Details:
Pink accessory wire connected but did not use pink/white wire.
Any help would be great. Thanks a bunch guys.
Posted By: ziggyb222
Date Posted: December 25, 2011 at 7:23 AM
Pink is for ignition and the orange is for acc... make sue you have that wire connected correctly or the unit might not go into program mode...
Date Posted: December 25, 2011 at 8:35 AM
Yes that correct. I mistyped. Pink from the box goes to orange at vehicle and orange from box goes to red at the vehicle.
Date Posted: December 25, 2011 at 9:11 AM
I show the red in ur vehicle as an ignition wire.. I have yellow listed as the acc wire.. Did you verify the wires at the swith with a meter... you will want to check it...
Posted By: tedmond
Date Posted: December 25, 2011 at 10:33 AM
recheck wiring.
------------- Ted
Compustar Expert
Date Posted: December 26, 2011 at 8:13 AM
You guys were correct. I had the accessory wire connected to the wrong lead at the ignition cyl. Just to be clear, I want to connect the pink wire from box to red accessory wire at the lock cyl and the pink/white box wire to yellow accessory wire at the lock cyl?
Posted By: offroadzj
Date Posted: December 26, 2011 at 8:26 AM
I don't have that vehicle wiring in front of me, but pink goes to the ignition wire, orange goes to the accessory wire, and pink/white goes to a secondary igition / accessory wire.
One thing I've noticed on that unit is that when you get all the connections made, the LED will flash consistantly and won't allow programming through the push button. If you have a bitwriter it will come up as no transmitters programmed. You have to press any button on the transmitters to allow it to program.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
