2005 toyota solara, ignition, starter wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129848
Printed Date: May 10, 2026 at 3:02 AM
Topic: 2005 toyota solara, ignition, starter wires
Posted By: mysticalp
Subject: 2005 toyota solara, ignition, starter wires
Date Posted: December 25, 2011 at 1:47 PM
Hello...
I am in need of some advice as I have not encountered this before. I am trying to hoo up an Autostart to a 2005 Toyota Solara. The Solara has 2 Ignition wires and 2 Starter wires. The Autostart (AS-1272) Has a jumper for the 5th relay (Accessories 2 Jumper, Ignition 2 Jumper, Starter 2 Jumper). My question is: DO I use both jumpers?? (Ignition & Starter) if so, how would I accomplish this as there is only one wire (green) for the 5th relay? Any advice/help would be much appreciated!
Thanks in advance for your time.... ------------- Pete
Posted By: tedmond
Date Posted: December 25, 2011 at 1:50 PM
use the 5th relay for your additional ignition.
the secondary start use a relay and connect like so
85 - ground when running (status output)
86 - start (+) from unit
87 - constant 12v
30 - second start wire.
or
85 - second start (-) from unit
86 - constant 12v
87 - constant 12v
------------- Ted
Compustar Expert
Date Posted: December 25, 2011 at 1:59 PM
That's great! Thanks for your reply and expertise! I will do this and let you know. I will use your first method. Thanks again!
Pete. ------------- Pete
Posted By: howie ll
Date Posted: December 25, 2011 at 6:16 PM
First method, GWR to 85 is safer, that way there's NO continuity between the starter wires.
Except if you only have one GWR and it's already running a by-pass, don't forget to diode them away from each other.
Date Posted: December 25, 2011 at 11:13 PM
Thanks for the tip howie II. I used the first method and everything checked out! Your input and help is very much appreciated!
------------- Pete
