2012 Camry Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130015
Printed Date: April 28, 2024 at 3:08 PM
Topic: 2012 Camry Alarm/Remote Start Wiring
Posted By: keanevann
Subject: 2012 Camry Alarm/Remote Start Wiring
Date Posted: January 03, 2012 at 2:26 PM
Hi everyone. I've searched everywhere I can think of and cant seem to find any info on wiring in a 2012 Toyota Camry. Can someone help me out? Im installing a Python 574 in his car this upcoming weekend and need to know what goes where, haha. DIRECTWIRE would probably be my best friend. Thanks for your help.
Posted By: offroadzj
Date Posted: January 03, 2012 at 3:49 PM
Readyremote.com wiring is showing this for 2012:
12volts white (120A) + dash fuse box, white 1 pin plug (3E), pin 1
Starter blue + ignition switch, white 8 pin plug, pin 7
Notes: On vehicles with Smart Key, the SS1 - SS2 wires are red - purple (-) at the engine switch, black 10 pin plug, pins 5 and 1.
Second Starter lt. green + ignition switch, white 8 pin plug, pin 3
Notes: On vehicles with Smart Key, it is pink (+) at the Certification ECU behind the glove box, white 18 pin plug, pin 5.
Ignition black + ignition switch, white 8 pin plug, pin 6
Notes: On vehicles with Smart Key, it is black (+) in the driver kick, gray 20 pin plug, pin 11.
Second Ignition pink + ignition switch, white 8 pin plug, pin 1
Notes: On vehicles with Smart Key, it is pink (+) at the dash fuse box, rear, white 56 pin plug (3A), pin 27.
Third Ignition N/A
Accessory white + ignition switch, white 8 pin plug, pin 2
Notes: On vehicles with Smart Key, it is white (+) at the dash fuse box, rear, white 40 pin plug (3B), pin 23.
Second Accessory N/A
Keysense green (without Smart Key only) - Body ECU, white 30 pin plug, pin 17
Notes: The Body ECU is under the driver dash, attached to the right side of the dash fuse box.
Power Lock blue (passenger door lock switch) - Body ECU, white 30 pin plug, pin 9
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm arm wire.
Power Unlock green (passenger door lock switch) - Body ECU, white 30 pin plug, pin 10
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm disarm wire.
Lock Motor red 5 wire driver kick, white 18 pin plug, pin 18
Unlock Motor gray 5 wire driver kick, white 18 pin plug, pin 12
Parking Lights+ pink + dash fuse box, white 36 pin plug (3C), pin 5
Parking Lights- white - Body ECU, white 30 pin plug, pin 30
Hazards white - A/C control assembly, black 16 pin plug, pin 4
Turn Signal(L) yellow + dash fuse box, white 36 pin plug (3C), pin 22
Turn Signal(R) green + dash fuse box, white 36 pin plug (3C), pin 19
Reverse Light pink + dash fuse box, white 36 pin plug (3C), pin 7
Door Trigger blue - dash fuse box, white 36 pin plug (3C), pin 15
Dome Supervision lt. green - dash fuse box, rear, white 40 pin plug (3B), pin 35
Trunk/Hatch Pin white - dash fuse box, white 36 pin plug (3C), pin 9
Hood Pin purple - dash fuse box, white 40 pin plug (3D), pin 25
Trunk/Hatch Release use trunk release motor
Power Sliding Door N/A
Factory Alarm Arm red (driver door key cylinder) - Body ECU, white 30 pin plug, pin 11
Factory Alarm Disarm gray (driver door key cylinder) double - Body ECU, white 30 pin plug, pin 24
Disarm No Unlock use keysense
Tachometer green ac data link connector, white 16 pin plug, pin 9
Wait to start N/A
Brake Wire red + brake switch, white 4 pin plug, pin 1
Parking Brake yellow - dash fuse box, white 40 pin plug (3D), pin 20
Horn Trigger lt. blue - dash fuse box, white 40 pin plug (3D), pin 15
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Modules: Not Available
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: January 03, 2012 at 3:51 PM
Sorry for the formatting being all weird, I couldn't get it to paste nicely and there was no way I was typing it all out.. lol. Here is a link to the site: Here------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: January 04, 2012 at 4:57 PM
Thank you very much. I wasnt aware of that site.
