camry 2003 pkall
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130046
Printed Date: May 22, 2024 at 2:27 PM
Topic: camry 2003 pkall
Posted By: patrick_0207
Subject: camry 2003 pkall
Date Posted: January 04, 2012 at 6:07 PM
Hi,
I installed a viper 5301 on my 2003 4 cyl camry and I can't seem to figure out how to program the PKALL.
I located the key sense wire and the tx/rx wires. Connected the PKALL to the viper using D2D. I also made sure to insert both connectors before the LED turns on. After inserting the key in the ignition, the LED remains steady.
Any help would be greatly appreciated
Thanks!
Posted By: kreg357
Date Posted: January 04, 2012 at 6:37 PM
There was a change going on with the transponder at that time.  It is possible that you have an different setup in your car.
What colors are the RX & TX wires you connected to?  If they are as listed below, you should wire differently.
2003
RX = Pin 4 RED / Blue
TX = Pin 5 Blue / YELLOW
The PKALL is actually a Fortin Key-Override-All with DBI D2D.  Here is a link to the Fortin install guide for a 2003 4 Cylinder Camry.
The wire colors might be different on the PKALL but the name and pin position will be the same.
https://ifar.ca/download/708/key-override-all_toyota_camry_%282003-2004%29.rev-a.pdf
If your TX and RX colors are as below, you have the right wiring setup.
2003 - 2006
RX = Pin 4 GREEN / WHITE
Date Posted: January 04, 2012 at 6:47 PM
They are wired as:
Key Sense = Blue (Next to WHITE/ black wire)
While running --> Blue/white on viper aux remote harness (status output)
The wiring diagram included with my bypass module was different
https://www.xpresskit.com/DocumentDownload.aspx?documentid=6226&productid=196&firmwareid=1636
The one you sent me requires cutting wires at the ignition barrel whereas the one I got only requires connecting 3 wires to the ignition barrel. I bought the PKALL because I read in this forum that it is much easier to install on toyotas.
Thanks!
Date Posted: January 04, 2012 at 9:23 PM
2003
2003 - 2006
Thanks a lot!
Just wired it according to the above diagram and it works flawlessly!
Something else I noticed is whenever I leave my headlights on "auto" mode. If I turn on my car with the remote starter and the starter times out. The headlights stay on.
Is there any way to get them to turn off?
Usually whenever I turn off my car (using the key in the ignition) the headlights turn off 5 seconds after I lock the car.
Posted By: kreg357
Date Posted: January 05, 2012 at 9:50 PM
Try connecting the Vipers  Rearm output to the Camry's Driver Door Trigger.
H2/2       LIGHT GREEN / WHITE             (-) 200mA FACTORY ALARM ARM OUTPUT
DRIVER DOOR TRIGGER IS RED / GREEN(-) AT LOWER LEFT OF THE FUSEBOX.  Here is a picture : https://www.bulldogsecurity.com/diagrams/Images.asp?ImageID=1082&link=Bulldog
Posted By: new12
Date Posted: February 24, 2013 at 6:09 PM
where are these wire located? I've tried to install my 2004 camry today but can't find these 2 wires when installing XK05-PTI bybass module.
Posted By: jstruckman
Date Posted: February 25, 2013 at 12:56 PM
New12 you most likely do not have a transponder. Most 4 cylinder Camrys in those years did not come with them. If you do not have a transponder right at the ignition switch then no need for a bypass. My 04 Camry 4 cylinder did not have a transponder.
