viper 5704, 02 blazer, door lock, dome
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130585
Printed Date: May 28, 2024 at 11:52 PM
Topic: viper 5704, 02 blazer, door lock, dome
Posted By: roadrage2006
Subject: viper 5704, 02 blazer, door lock, dome
Date Posted: February 11, 2012 at 11:18 PM
Hello everyone! I'm in stalling a Viper 5704 remote start into a 2002 Chevy S10 Blazer and I need a little help with a few items:
1.For the power locks can I connect the alarm directly to the light blue and white wire at the BCM or will I need relays like the DEI451M?
2.Should I wire the OEM alarm disarm and arm wires or the disarm only?
3.If I wire the domelight supervision wire to the LF door trigger do I need to use a relay there or diode isolate. Would I be better off hooking up to the interior light by the steering wheel with a relay?
Thanks for any help, Jack.
Posted By: gabedemelo
Date Posted: February 11, 2012 at 11:35 PM
you need 451 for doorlocks since theyre + plus put the GREEN/ black disarm wire to the light green vehicle disarm,..... all wires can be found in the large harness under drivers dash,... tach can be found in taped harness to the far right under drivers dash a little lower than the large harness sort of below center console but easily accessible from drivers dash
Item Wire Color Polarity Wire Location
12 Volts RED / white (50A) + ignition harness
Second 12 Volts red (40A) + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Third Accessory N/A
Keysense lt. green - ignition harness or BCM, lt. blue plug, pin B9
The BCM is in the center console, below the radio.
Data Bus yellow (resistor code), ORANGE / black (ground) Passlock 2 Passlock sensor on ignition key cylinder
Can Bus High N/A
Can Bus Low N/A
Can Bus Sw purple (J1850 Class 2 Serial Data) data data link connector, black 16 pin plug, pin 2
Power Lock lt. blue + BCM, brown plug, pin A4
Power Unlock white (all doors); lt. green (driver door only) +; - BCM, brown plug, pin A3; lt. blue plug, pin A4
Lock Motor gray 5 wire dash relay block next to dash fuse block
Driver Unlock Motor tan 5 wire dash relay block next to dash fuse block
Parking Lights (-) white - BCM, lt. blue plug, pin A5
The BCM is in the center console, below the radio. This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground.
Parking Lights (+) lt. blue + dash relay block next to dash fuse block
Hazards same as turn signals
Turn Signal (Left) lt. blue/white (F), yellow/black (R) + turn signal switch
Turn Signal (Right) dk. blue/white (F), dk. GREEN / WHITE (R) + turn signal switch
Headlight white + BCM, lt. blue plug, pin A11
AutoLights
Reverse Light lt. green + driver kick, harness to rear
Left Front Door Trigger tan - BCM, purple plug, pin B4
Right Front Door Trigger orange - BCM, purple plug, pin B2
Left Rear Door Trigger dk. blue/white - BCM, lt. blue plug, pin B11
Right Rear Door Trigger same as left rear door trigger
Dome Supervision gray/black - BCM, lt. blue plug, pin A3
Trunk/Hatch Pin see rear glass pin
Rear Glass Pin pink/black - BCM, lt. blue plug, pin B10
Hood Pin N/A
Trunk/Hatch Release black (rear handle switch) - BCM, purple plug, pin B1
Trunk Release Motor BLACK/ white + dash relay block next to dash fuse block
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green (driver door key cylinder) - BCM, purple plug, pin B3
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt N/A
Tachometer white ac instrument cluster, gry 24 pin plug, pin A3 or PCM, grn plug, pin 10
The PCM is on the passenger side fender.
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal PURPLE / white + clutch switch
Fuel Pump gray + underhood fuse block, red 32 pin plug, pin F1
Rear Defroster white - latched HVAC Control, blue 4 pin plug, pin 3
Mirror Defroster same as rear defroster
Left Front Heated Seat pink + resistor driver heated seat switch
Right Front Heated Seat pink + resistor passenger heated seat switch
Speed Sense dk. GREEN / WHITE ac BCM, lt. blue plug, pin B1
Brake Wire white + brake switch or steering column
Parking Brake lt. blue - parking brake switch or BCM, brown plug, pin B10
Horn Trigger black - horn switch or BCM, brown plug, pin A9
The BCM is in the center console, below the radio. The horn trigger wire is available at the BCM only on vehicles with factory alarm.
------------- GreenGables
Posted By: offroadzj
Date Posted: February 11, 2012 at 11:38 PM
1) If the unit has dual polarity lock outputs (switch wires for positive output) then you can try connecting them straight to the light blue and white wires. But chances are you will need the 451m to control the (+) locks.
2) Do you have a factory alarm? If not then don't worry about it; if you do and you don't care about having it arm with the aftermarket remote than don't worry about the factory arm. Still connect disarm so you don't have to worry about the alarm accidentally going off.
3) You shouldn't have to worry about the domelight supervision. I'm pretty sure that the BCM will automatically turn on the domelight when the doors are unlocked. You can test it by watching the light when locking / unlocking the vehicle with the remote.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: February 11, 2012 at 11:49 PM
dome supervision wont work while vehicle is running when you unlock unless you use dome sup,... dei stopped using the flipflop +/- lock wires quite a while ago not sure why but im assuming to sell more products
Date Posted: February 12, 2012 at 12:00 AM
Thanks guys, I have been pulling my hair out trying to figure these last few items out!!!!!!!!!!!
Date Posted: February 12, 2012 at 11:16 AM
Ahhh... I wasn't aware of the domelight supervision being off when started. I guess a connection is required.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: howie ll
Date Posted: February 12, 2012 at 12:00 PM
The reason they dropped the flip flops is they were sick of having to tell the fools to install conditioning diodes every time they fed to a processor or relay because of back feeds. And of course they sell more 451s
Date Posted: February 12, 2012 at 4:12 PM
The install is going good and I am hoping to get this wrapped up tonight. The door locks worked our great using the 451m. For the dome light supervision I am planning on using pin A3 which is the gray/black wire on the BCM that controls the courtesy lamp relay. When I ground this pin I can hear the relay under the dash click and the dome light comes on. Is it ok to run the dome light supervision wire directly to this since it seems to just be a relay trigger or do I need to hook up a relay?
Posted By: howie ll
Date Posted: February 12, 2012 at 4:44 PM
Run it directly but use a diode, 1N4004 in line, band towards 5704.
