2005 f150 factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131466
Printed Date: May 20, 2024 at 10:55 PM
Topic: 2005 f150 factory alarm
Posted By: GLASPEY_98
Subject: 2005 f150 factory alarm
Date Posted: May 22, 2012 at 10:07 PM
I have a 2005 f150 with the factory keyless entry. Lost the keyfob and now cannot disable the security on the truck. Would like to be able to start my vehicle. What can I do?
Posted By: chev104275
Date Posted: May 23, 2012 at 9:36 AM
The factory doesn't put starter kill in there systems. Unless were talking about immobilisers. But you're saying keyless entry I would drop the drivers side of the dash and look at the wiring going to the ingition and look for a cut wire going to a relay. Of I remember correctly your starter wire should be RED / blue
------------- If i Can't Install it I Don't need it Joe
Posted By: jim hunter
Date Posted: May 23, 2012 at 3:58 PM
if it has the factory alarm turning the ignition on will disarm it as will turning the key in the drivers door to unlock, if neither of these allow the truck to start it either has an aftermarket alarm in it or something else is wrong
