Print Page | Close Window |
2008 explorer sport trac pickupPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132182 Printed Date: May 23, 2024 at 4:30 AM Topic: 2008 explorer sport trac pickup Posted By: Thack79 Subject: 2008 explorer sport trac pickup Date Posted: September 13, 2012 at 1:07 PM is this the same layout as the regular explorer. can someone post the wire guide for me. thanx Replies: Posted By: tommy... Date Posted: September 13, 2012 at 2:47 PM 2008 Ford Sport Trac DirectWire 2.0 Vehicle Information
All Products Item Wire Color Polarity Wire Location 12 Volts red (50A), yellow/red (50A), blue/red (50A) + SJB, black 32 pin plug (E), pins 32, 4, and 1 The SJB (Smart Junction Box) is under the driver dash. Second 12 Volts PURPLE / red (15A) + ignition switch, black 7 pin plug, pin 4 Starter blue/white + ignition switch, black 7 pin plug, pin 7 Second Starter N/A Ignition WHITE/ orange + ignition switch, black 7 pin plug, pin 1 Second Ignition N/A Third Ignition N/A Accessory PURPLE / green + ignition switch, black 7 pin plug, pin 6 Second Accessory N/A Third Accessory N/A Keysense blue/gray + ignition switch, black 7 pin plug, pin 5 Data Bus yellow/orange (TX), PURPLE / gray (RX) data PATS Transceiver, black 4 pin plug, pins 3 and 4 The PATS (Passive Anti-Theft System) Transceiver is around the ignition key switch. The PATS ignition wire is WHITE/ orange in pin 1 and the ground wire is PURPLE / white in pin 2. Can Bus High gray/orange data data link connector, pin 3 or SJB, gray 32 pin plug (D), pin 16 The SJB (Smart Junction Box) is under the driver dash. Can Bus Low PURPLE / orange data data link connector, pin 11 or SJB, gray 32 pin plug (D), pin 15 The SJB (Smart Junction Box) is under the driver dash. Can Bus Sw N/A Power Lock gray / YELLOW - driver kick or SJB, black 32 pin plug (B), pin 27 The SJB (Smart Junction Box) is under the driver dash. Power Unlock PURPLE / gray - driver kick or SJB, black 32 pin plug (B), pin 26 The SJB (Smart Junction Box) is under the driver dash. Lock Motor gray/brown 5 wire driver kick or SJB, brown 32 pin plug (A), pin 4 The SJB (Smart Junction Box) is under the driver dash. Driver Unlock Motor blue/green 5 wire driver kick or SJB, brown 32 pin plug (A), pin 17 The SJB (Smart Junction Box) is under the driver dash. Passenger Unlock Motor PURPLE / gray 5 wire driver kick or SJB, brown 32 pin plug (A), pin 1 The SJB (Smart Junction Box) is under the driver dash. Parking Lights (-) gray - headlight switch or SJB, gray 32 pin plug (D), pin 3 The SJB (Smart Junction Box) is under the driver dash. May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ blue at the headlight switch, gray 10 pin plug, pin 7. See Tech Doc 1096 for wiring information. Parking Lights (+) blue/white + driver kick or SJB, brown 32 pin plug (A), pin 11 The SJB (Smart Junction Box) is under the driver dash. Hazards BROWN / yellow - hazard switch or SJB, gray 32 pin plug (D), pin 4 The SJB (Smart Junction Box) is under the driver dash. Turn Signal (Left) blue/green (F); gray/brown (R) + SJB, black 32 pin plug (E), pin 24; brown 32 pin plug (A), pin 25 The SJB (Smart Junction Box) is under the driver dash. Turn Signal (Right) yellow/purple (F); PURPLE / orange (R) + SJB, black 32 pin plug (E), pin 27; brown 32 pin plug (A), pin 27 The SJB (Smart Junction Box) is under the driver dash. Headlight blue/white - headlight switch or SJB, gray 32 pin plug (D), pin 14 The SJB (Smart Junction Box) is under the driver dash. May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ blue at the headlight switch, gray 10 pin plug, pin 7. AutoLights PURPLE / green (interrupt to turn off autolights) - headlight switch or SJB, gry 32 pin plg (D), pin 9 The SJB (Smart Junction Box) is under the driver dash. Reverse Light BROWN / blue + driver kick or SJB, brown 32 pin plug (A), pin 6 The SJB (Smart Junction Box) is under the driver dash. Left Front Door Trigger GREEN/ purple - N.C. driver kick or SJB, black 32 pin plug (B), pin 17 The SJB (Smart Junction Box) is under the driver dash. Right Front Door Trigger white - N.C. driver kick or SJB, black 32 pin plug (B), pin 19 The SJB (Smart Junction Box) is under the driver dash. Left Rear Door Trigger green - N.C. driver kick or SJB, black 32 pin plug (B), pin 20 The SJB (Smart Junction Box) is under the driver dash. Right Rear Door Trigger yellow - N.C. driver kick or SJB, black 32 pin plug (B), pin 21 The SJB (Smart Junction Box) is under the driver dash. Dome Supervision yellow/gray (dome lamps), purple (puddle lamps) + driver kick or SJB, brown 32 pin plug (A), pins 8 and 7 The SJB (Smart Junction Box) is under the driver dash. Trunk/Hatch Pin N/A Rear Glass Pin N/A Hood Pin N/A Trunk/Hatch Release N/A Trunk Release Motor N/A Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm PURPLE / green and YELLOW /GREEN (driver door keypad) both - driver kick, door harness Factory Alarm Disarm N/A Disarm No Unlock N/A Trunk Alarm Shunt N/A Tachometer NOT purple ac any fuel injector Wait to Start N/A Neutral Safety N/A Clutch Pedal N/A Fuel Pump PURPLE / green + inertia fuel shutoff switch, gry 3 pin plug, pin 2 The inertia fuel shutoff switch is in the passenger kick. Rear Defroster N/A Mirror Defroster gray/brown + latched driver kick or SJB, brown 32 pin plug (A), pin 5 The SJB (Smart Junction Box) is under the driver dash. Left Front Heated Seat yellow/blue + latched heated seat switch, gray 10 pin plug, pin 4 Right Front Heated Seat gray/blue + latched headed seat switch, gray 10 pin plug, pin 2 Speed Sense PURPLE / orange ac wiper motor or PCM, middle plug, pin 1 The PCM (Powertrain Control Module) is in the engine compartment, on the passenger side firewall. Brake Wire PURPLE / white + brake switch or SJB, brown 32 pin plug (A), pin 15 The SJB (Smart Junction Box) is under the driver dash. Parking Brake gray/blue - parking brake switch or SJB, black 32 pin plug (B), pin 18 The SJB (Smart Junction Box) is under the driver dash. Horn Trigger blue/white - horn switch or SJB, gray 32 pin plug (C), pin 6 The SJB (Smart Junction Box) is under the driver dash. Wipers blue/orange (L), PURPLE / orange (H), blk/blu (grnd) - wiper switch, black 16 pin plug, pins 16, 9, and 15 Left Front Window (Up/Down) blue/gray - yellow/purple A master window switch, blue 8 pin plug, pins 5 and 1 Right Front Window (Up/Down) BROWN / yellow - GREEN/ orange A driver kick, door harness Left Rear Window (Up/Down) blue/orange - yellow A driver kick, door harness Right Rear Window (Up/Down) gray/purple - BROWN / green A driver kick, door harness Sun Roof (Open/Close) pur/brn - yel/org (function with ignition on only) - sun roof switch, 6 pin plug, pins 2 and 5, or pins 5 and 1 Sun Roof (Limit/Close) N/A Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Radio 12V blue/red + radio, gray 24 pin plug, pin 1 Radio Ground BLACK/ blue - radio, gray 24 pin plug, pin 13 Radio Ignition GREEN / WHITE + radio, gray 24 pin plug, pin 2 Radio Illumination (CAN BUS) Factory Amp Turn-on yellow/purple or PURPLE / red + radio, gray 24 pin plug, pin 7 or gray 8 pin plug, pin 4 Power Antenna N/A Left Front Speaker (+/-) white - WHITE/ brown +,- radio, gray 24 pin plug, pins 8 and 21 If equipped, the amplifier is above the passenger kick. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the amplifier, gray 14 pin plug, pins 13 and 6. Right Front Speaker (+/-) WHITE/ purple - WHITE/ orange +,- radio, gray 24 pin plug, pins 11 and 12 If equipped, the amplifier is above the passenger kick. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier, gray 14 pin plug, pins 11 and 4. Left Rear Speaker (+/-) WHITE/ green - BROWN / yellow +,- radio, gray 24 pin plug, pins 9 and 22 If equipped, the amplifier is above the passenger kick. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier, gray 14 pin plug, pins 12 and 5. Right Rear Speaker (+/-) BROWN / white - BROWN / blue +,- radio, gray 24 pin plug, pins 10 and 23 If equipped, the amplifier is above the passenger kick. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the amplifier, gray 14 pin plug, pins 10 and 3. Center Channel (+/-) N/A Subwoofer (+/-) PURPLE / green - GREEN / WHITE +,- radio, gray 8 pin plug, pins 1 and 2 Aux. Audio Input Left (+/-) blue - YELLOW /GREEN (w/o SYNC) +,- radio, gray 16 pin plug, pins 7 and 8 Aux. Audio Input Right (+/-) blue/green - WHITE/ green (w/o SYNC) +,- radio, gray 16 pin plug, pins 6 and 14 RSE Video (+/-) RSE Audio Left (+/-) green - gray +,- radio, gray 16 pin plug, pins 1 and 2 RSE Audio Right (+/-) purple - yellow +,- radio, gray 16 pin plug, pins 9 and 10 Satellite Radio 12 Volts red + Satellite Radio Receiver, black 12 pin plug, pin 9 If equipped, the Satellite Radio Receiver is above the passenger kick. Satellite Radio Ground BLACK/ blue - Satellite Radio Receiver, black 12 pin plug, pin 3 Satellite Radio Ignition (CAN BUS) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) GREEN/ orange - blue/brown +,- Satellite Radio Rcvr, black 12 pin plg, pins 5, 11 Satellite Audio Right (+/-) PURPLE / brown - yellow/blue +,- Satellite Radio Rcvr, black 12 pin plg, pins 6, 12 Item Size Depth Location Headunit double DIN center of dash Left Front Speaker 6 x 8 left front door Left Front Tweeter N/A Right Front Speaker 6 x 8 right front door Right Front Tweeter N/A Left Rear Speaker 6 x 8 left rear door Left Rear Tweeter N/A Right Rear Speaker 6 x 8 right rear door Right Rear Tweeter N/A Center Channel N/A Subwoofer 8 behind driver side rear seat Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner above passenger kick ------------- M.E.C.P & First-Class Go slow and drink lots of water...Procrastinators' Unite...Tomorrow! Posted By: Thack79 Date Posted: September 13, 2012 at 4:39 PM Thanks man. Appreciated
Posted By: tommy... Date Posted: September 13, 2012 at 4:58 PM You're Welcome...
------------- M.E.C.P & First-Class Go slow and drink lots of water...Procrastinators' Unite...Tomorrow! Posted By: vinchinzo Date Posted: October 23, 2012 at 12:50 PM Now thats alot of wires! LOL
------------- When in doubt....kick it! |
