lock actuators in removable doors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132494
Printed Date: May 20, 2024 at 3:59 PM
Topic: lock actuators in removable doors
Posted By: prdjr165
Subject: lock actuators in removable doors
Date Posted: October 26, 2012 at 3:06 PM
Has anyone installed door lock actuators in a 1999 jeep wrangler with removable doors?my question is how did you wire them-did you use some kind of plug so the doors can still be removed.
Posted By: Mike M2
Date Posted: October 26, 2012 at 4:48 PM
Yep, many time and since it's just 2 wires just use covered spade terminals, reversing one side so it can only plug in one way...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: October 26, 2012 at 5:17 PM
What about the contactors from sliding door kits?
Look in the Metra catalogue.
Posted By: tommy...
Date Posted: October 27, 2012 at 8:08 AM
Male/Female Spades... Molex plugs from radio shack... All have been used in the past for this job...
------------- M.E.C.P & First-Class
Posted By: howie ll
Date Posted: October 27, 2012 at 9:01 AM
Tommy, just noticed your signature. May I use I can't be bothered with apathy?
Since I'm semi-retired, it's brass monkeys and the clocks in the UK go to winter time tomorrow, I want to procrastinate until spring.
Posted By: tommy...
Date Posted: October 27, 2012 at 9:11 AM
Of Course...
If i remember correctly... The nylon straps that hold the door from opening fully has slits in both ends and is a nice sleeve for after-market wiring... ------------- M.E.C.P & First-Class
Posted By: prdjr165
Date Posted: October 27, 2012 at 11:07 PM
all good idea's!i will see the vehicle next week to get an idea of which set-up to use..i like the sliding door contacts-just not sure if they'll line up correctly.
Posted By: howie ll
Date Posted: October 28, 2012 at 1:21 AM
Lining them up is where the plasticine (play dough? modelling clay?) comes in.
