prostart toyota corolla 2006
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132580
Printed Date: April 29, 2024 at 9:55 PM
Topic: prostart toyota corolla 2006
Posted By: wooohooo
Subject: prostart toyota corolla 2006
Date Posted: November 05, 2012 at 1:43 AM
So I'm in the process of installing a car alarm which I haven't done before.
Anyways, I have a few problems...
1) Remote start doesn't start, but the antenna is blinking rapidly.
2) Parking light does not turn on. The diagrams say to connect to door trigger wire. I attached to + parking light, shows 12 volts in ACC and Run positions.
3) I haven't installed my bypass but I put the key in to bypass the remote starter and try with the remote but nothing.
Do I need a relay for the parking light? One wire diagram I read suggests a relay is needed. Also, I connected both 12 volt constants together from the remote starter to the ignition constant. Should I connect this directly to the battery?
Thanks in advance!
Posted By: howie ll
Date Posted: November 05, 2012 at 2:40 AM
Show what you've connected to where.
In what world does the parking light have anything to do with door trigger?
Door trigger is red, NEG (-), front of fusebox, parking lights are something like GREEN / WHITE NEG (-) steering column loom.
You have 2 ignition wires, connect both (use a relay) if the Prostart doesn't have this provision.
Info should be on this site, either Vehicle Wiring or Downloads/Manuals section.
Ignition constants or thick white feed to fusebox , either are adequate for your 12v+ constant.
Ground to an existing bolt in the kick panel area, scrape the metal bare under the bolt.
Posted By: howie ll
Date Posted: November 05, 2012 at 2:43 AM
You will need a by-pass also connect key sense*, 05 wiring is in the vehicle wiring section, it's the same as 06.
*From status output (GWR) or third NEG (-) on Prostart if one is available. If not split the GWR to keysense and by-pass via 2 1N4004 diodes, bands towards Prostart.
Posted By: smokeman1
Date Posted: November 05, 2012 at 6:44 AM
Which model of Prostart are you installing?
Parking lights to door trigger...ummm, Haven't tried that one. lol
Link to Bulldog security wire GUIDE...https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
And as Howie suggest, please post what wires are connected to what on the car. ------------- When all else fails, Read the Instructions
Posted By: wooohooo
Date Posted: November 05, 2012 at 10:36 AM
Thanks for the replies so far.
On the bottom of the wiring diagrams it says:
NOTE #3: For the DOOR PIN TRIGGER, on the 2006 use the RED (-) wire, FRONT of the
FUSE BOX, 10-Pin Plug
NOTE #4: For DOME LIGHT SUPERVISION on the 2006, use the DOOR PIN TRIGGER wire,
RED (-) wire, FRONT of the FUSE BOX, 10-Pin Plug
And for the wires connected...
Connected two 12volt constants together then connected to single 12volt constant wire in car
Starter wire
Ignition 1
Ignition 2 - 5th relay on remote start + jump settings
Accessory/heat
Parking Lights + to green in driver kick panel
Brake
Ground – connected to a bolt where another ground wire is attached
Hood pin switch – went through firewall grommet
Ground when running to bypass (bypass not hooked up yet)
Posted By: wooohooo
I also meant to say it's the Prostart 3471
Posted By: wooohooo
Date Posted: November 05, 2012 at 10:41 AM
I can't find a way to edit my post...
so I also have the or what I think is the door trigger/domelight connected to the negative door input.
Posted By: howie ll
Date Posted: November 05, 2012 at 10:53 AM
On this car as most Toyotas door trigger is the red as stated, dome supervision not needed.
Try and go through your wiring, key in ignition to see if at least your lights on the instrument panel are coming on.
Make sure your hood pin works correctly, make sure it only goes to ground when hood is opened.
Check your R/S outputs, also have you programmed the green wire as a second ignition?
Parking lights are NEG (-) GREEN / WHITE? (test) in steering column loom.
So that's two mistakes so far and you still haven't given us your wire colour to wire colour connections.
Parking lights are the outside lights that come on when you turn you lighting switch to the first position.
Dome light is what comes on when you open a door and will stay on after closing for 1 minute or until you either turn on the ignition or exit and lock the car.
I had to write those two sentences in bold because I'm not sure you understand what's going on here or what you're quite supposed to be doing, soon your name will be Booohooo.
So please pay attention and please do what we ask for such as your connections, time trouble and $$$ saved in the long run.
Posted By: wooohooo
Date Posted: November 05, 2012 at 11:00 AM
Thanks Howie.
Sorry, I don't know what I was thinking last night about the door trigger. I mixed it up.
I meant to say the parking light is connected, but the parking lights do not come on when I try to program it via the hoodpin switch.
I can't even get into program mode, so maybe I hooked up the parking light wrong? Although I do get voltage in the right positions...
Posted By: howie ll
Date Posted: November 05, 2012 at 11:39 AM
That's why I gave you a NEGATIVE switched option. Yellow/white on 3pin harness of Prostart.
Did you test and verify your hood switch as only going to ground on opening the hood?
There's also a purple wire on the 12 pin harness. Sounds silly but try grounding this wire, I used this trick to make a Prestige R/S enter programming mode and believe it or not it worked.
Last but not least two things:-
How are you joining your cables?
I should have mentioned this first but have checked for voltage should be around 12.5V+ between your ground and R/S fuses?
Posted By: howie ll
Date Posted: November 05, 2012 at 11:56 AM
Please read and digest pages 27 and 28 of the install guide.
Posted By: wooohooo
Date Posted: November 05, 2012 at 3:49 PM
R/S
2x12volt constant Red → White 12volt constant ignition
Purple Starter → Red Starter wire
Yellow Ignition → BLACK/ White Wire
Green (5th relay) –> BLACK / YELLOW Wire
Orange Accessories → blue/red wire
Black ground → Ground bolt in chassis
Grey hoot switch → Hood
Orange Brake switch (+) → GREEN / WHITE brake wire (near brake/cylinder)
Yellow Parking light output → Green wire in the wire harness
White (GWR) → blue/white wire on PKALL (haven't hooked up PKALL)
Gray – (Negative door input) → Red Door trigger wire
So I have gotten the parking light to be on now. Also the light on the antenna flashes rapidly but when I open the door, it stops.
When I plugged in the power, the unit clicked 4 times.
I can get into programming mode with both the hood pin and also through PAB.
I however, cannot start the car, no cranks or anything. I also did try grounding the purple wire from the 12 pin. I also tested voltage from the wires and also the pins and got 12+ volts.
Posted By: wooohooo
Date Posted: November 05, 2012 at 3:58 PM
I'm also just tying my cables in and using electrical tape to secure it. When I know it works, I'll solder it in, incase I made a mistake somewehre
Posted By: wooohooo
Date Posted: November 05, 2012 at 7:26 PM
Anyways, I GOT IT TO WORK!!!
The problem was actually the antenna itself. Replaced the antenna and it starts up like a charm
Thanks alot for your help, that helped alot too!
Posted By: wooohooo
Date Posted: November 06, 2012 at 3:46 PM
Well I had a problem? maybe arise.
If I lock my car door from inside the car, my remote starter doesn't nkow it's locked. When I try to unlock it, it doesn't work. I have to manually unlock it first before I can lock with the remote starter.
Also, when I manually lock the door, the antenna blinks rapidly like my locks are unlocked.
Any clue what the problem is?
Posted By: wooohooo
Date Posted: November 07, 2012 at 9:58 AM
Also, if I lock the doors while the door is open, this problem arises. If I close the door and lock the doors manually (sitting inside), I can still lock and unlock with the remote starter.
Posted By: wooohooo
Date Posted: November 07, 2012 at 2:56 PM
Anyone??
I'm thinking because the door trigger grounds when the door is open... thus turning off the antenna, perhaps I need a relay like the bulldogsecurity wiring diagrams suggest.
Do I do this?
https://www.bulldogsecurity.com/bdnew/newsite/pictures/pdfs/775%20for%20NEGATIVE%20DOMELIGHT%20SUPERVISION.pdf
Any help would be greatly appreciated. I would like this done before the weather dips too cold.
