remote start no longer working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133660
Printed Date: May 14, 2024 at 10:40 AM
Topic: remote start no longer working
Posted By: uncledeadly
Subject: remote start no longer working
Date Posted: February 21, 2013 at 9:42 PM
I installed a remo te start on a 2008 Honda Accord about a month ago. Everything worked well.....recently the user realized that the door chime would sound everytime the door was open (as though the key was in the ignition). They hadn't tried to start it remotely recently.
The fob no longer works on the doors or the trunk but the car wll crank but not fire.
It is a Prostart starter with a DBall bypass that I installed D2D.
Any ideas??
Posted By: chinadoll
Date Posted: February 22, 2013 at 2:24 AM
I guess the problem is about the remotes. Is that being strongly hit before? or Someone pierce the button of Trunk Release and Open ( the doors),you know the kits like that little trick very much.
Victor Electronics-China car security products manufacturer,supplier&exporter.
Posted By: offroadzj
Date Posted: February 22, 2013 at 6:06 AM
It sounds like there is back feeding in the keysense wire. I would change out to W2W to at least give you the ability to test. That may fix it as well. I have never had any luck with D2D on the DB-ALL
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: kreg357
Date Posted: February 22, 2013 at 7:36 AM
Agree with Kenny about going W2W.   Additionally, I would re-flash and then re-program the DB-ALL to the car.
Date Posted: February 22, 2013 at 10:40 AM
I have heard before that D2D can be  hit and miss and was thinking about changing it to w2w....I'll let  you know how it goes. Thanks and st ay tuned posted_image
Date Posted: March 03, 2013 at 9:28 AM
Just an update.
Turned out to be a blown , in line fuse. Don't know why it blew but just changed it out and see if it goes again. f it does I'll deal with it then.
Posted By: Chris Luongo
Date Posted: March 04, 2013 at 12:49 PM
uncledeadly wrote:
Just an update.
We seem to get a couple of Hondas with blown fuses after every snow or ice storm.
I've heard that if the customer leaves the wipers switched on, with the wipers stuck in snow or ice, and activates the remote starter, the remote starter's fuse will blow.
Customer can remember to always switch wipers off when parking, or possibly you could use a relay to interrupt the wipers during remote start.
