autopage ads al ca
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134446
Printed Date: June 06, 2024 at 12:37 PM
Topic: autopage ads al ca
Posted By: bobby speer
Subject: autopage ads al ca
Date Posted: June 27, 2013 at 9:53 AM
Is the Autopage idatalink ADS-AL CA immobilizer offered by Amazon the same as the ADS idatalink ADS-AL CA, or some copy, and what is a Flash Logic FL CAN?
Posted By: kreg357
Date Posted: June 27, 2013 at 11:31 AM
Looks like a standard iDatalink ADS AL-CA bypass module. Can't see for sure, but it might not be the
newer 64K ( or 128K ) module, as it has the older style graphics on the box.
The FLCAN is an ADS AL-CA bypass module OEM'd by Audiovox FlashLogic that has the FLC "DBI" firmware
flashed on it. FLC "DBI" is for Viper style D2D communications using the D2D harness.
They are the Multi series ( not Solo series ) that usually need to be flashed with the appropriate firmware prior
to use.
------------- Soldering is fun!
