2010 honda crosstour
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135453
Printed Date: June 08, 2024 at 7:55 AM
Topic: 2010 honda crosstour
Posted By: ccaudio
Subject: 2010 honda crosstour
Date Posted: December 03, 2013 at 11:18 PM
Hello I am going to install a remote start in a 2010 honda crosstour. I have no problem installing them just wanted to know what is the best bypass module. She only has 1 key so I can't use a universal one. I don't have a computer just a smart phone so a dball won't work I guess. Amy other suggestions.
Posted By: chev104275
Date Posted: December 04, 2013 at 5:37 AM
If you have anyone close to you that deals in idatalink stuff I would get an ads-al-ca flashed with the DL-HA3 firmware. The module will take care of pretty much everything for you (locks,factory alarm, data immobilizer, etc.) Also it only requires one key for programming
Posted By: kreg357
Date Posted: December 04, 2013 at 8:30 AM
I'm a big fan of the iDatalink bypass modules, too.  You can even look online for the ADS AL CA module from a seller that will flash with the correct DL-HA3 firmware prior to shipment.  Here is a link to the install guide  :
https://cdncontent2.idatalink.com/corporate/Content/Manuals/DL-HA3/ADS-AL(DL)-HA3-EN_20130909.pdf
There might be a viable alternative with the Fortin EVO-ALL.  They, too, are a full function bypass module similar to the ADS AL CA.  They come preloaded with the basic firmware and can be re-flashed with a specific firmware if needed.  However, the EVO-ALL with the basic Ver 4.09 or Ver 4.18 firmware will work for your vehicle and should be easy to find.  Here is a link to the install guide :
https://ifar.ca/download/12091/evo-all_honda_acura.rev-20131031.pdf
