2008 ford edge ignition bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135859
Printed Date: May 21, 2024 at 7:56 AM
Topic: 2008 ford edge ignition bypass
Posted By: dcesa1
Subject: 2008 ford edge ignition bypass
Date Posted: January 18, 2014 at 11:46 AM
Im installing the bypass module and was wondering which wires need to be connected. I have the Avital 4113 with the xpresskit pkfm. Can I connect the 2 just using the D2D connector or do I need to do the other wires also? The D2D connector connects the RX, TX, ignition, and ground.
Posted By: dcesa1
Date Posted: January 19, 2014 at 8:46 AM
bump
Posted By: smokeman1
Date Posted: January 19, 2014 at 10:30 AM
Go W2W on this. It is only 6 wires.
Per the PKFM Instructions:
Brown----- Blue status output 4113
Green-----TX Pin 2 at PATS connector
Pink---RX Pin 1 at PATS connector
Orange---Ignition at PATS Connector Pin 4
Red---12 volt constant
Black--- Ground
------------- When all else fails, Read the Instructions
Posted By: dcesa1
Date Posted: January 19, 2014 at 10:37 AM
what is the D2D connection for? it seems like it would be an easier way to connect all of the same wires.
Date Posted: January 19, 2014 at 10:59 AM
The way I read the PKFM instructions , TX, RX,ignition,GWR,are not supported in D2D
