09 murano transponder light and check eng
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136050
Printed Date: May 16, 2024 at 1:09 PM
Topic: 09 murano transponder light and check eng
Posted By: 97gss
Subject: 09 murano transponder light and check eng
Date Posted: February 11, 2014 at 7:27 PM
Currently working on an 09 murano for r/s. I turned the car on without the dash cluster plugged in or the bcm screwed back into place. Was checking wiring for IPDM. The car didn't want to cur off afterwards and was giving some weird beeps(cluster wasn't plugged in so I couldn't look at it). I made a few attempts to get it to cut off by pressing the button(not stepping on the brake). Then I finally plugged the cluster in, then pressed the button and it cut off, but the transponder light stayed on. Thought nothing of it, unplugged the cluster and continued to finish wiring. Now, when I start it, the check engine light and the transponder light stays on. Any ideas?? Going to attemp to disconnect the battery for awhile to see if that works.
Posted By: 97gss
Date Posted: February 11, 2014 at 11:33 PM
Got it straight. May have had 1 of the plugs out of the BCM. Reconnected the battery and it's fine.
Posted By: ziggyb222
Date Posted: February 12, 2014 at 9:03 AM
I am doing this vehicle this weekend...Using a Idata module for PTS and bypass...Any helpful tips?
