programming 2 stage code alarm shock sens
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136200
Printed Date: May 16, 2024 at 8:32 AM
Topic: programming 2 stage code alarm shock sens
Posted By: marklar65
Subject: programming 2 stage code alarm shock sens
Date Posted: March 01, 2014 at 8:05 PM
So im trying to figure out how to program the dual stage shock sensor via the remote on a Autopage rf-425. No directions in any of the manuals on how to adjust the sensitivity. Checked the sensor and no adjustment screw is present. So can anyone please inform me as to the correct procedure for setting it? Thanks in advance for helping to resolve this issue. Neighbors are getting frustrated, and so am I ........
Posted By: lectricguy
Date Posted: March 03, 2014 at 6:46 PM
I'm assuming you have the shock sensor that came with the rf425. The shock sensor is wedge shaped. There is an adjustment screw in the thickest part of the shock sensor housing on the top side, the side away from the mounting tabs. It is recessed, and may be difficult to spot. Turning the adjustment screw counterclockwise will reduce the sensitivity. Start with 1/4 turn and retest.
Hope this helps.
------------- Lectric Guy
Date Posted: March 03, 2014 at 6:50 PM
It was night time and I wasn't wearing my glasses, so I will look for it again! Thank you for the info! Greatly appreciated as always.
