5 pin relay to light strip
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136419
Printed Date: May 02, 2024 at 7:10 PM
Topic: 5 pin relay to light strip
Posted By: jamesrsanders
Subject: 5 pin relay to light strip
Date Posted: April 08, 2014 at 5:13 PM
Hello,
OK where do i start. I have a toyota corolla that i have an alarm. what i want to do is i have a led strip i want to add some how, the strip to the alarm via a ralay that i have on hand or by any other means. i want to make the relay turn on a device when the car is turned off. i have played with this for over a week now... thanks in advance.
------------- james
Posted By: the12volt
Date Posted: April 08, 2014 at 5:29 PM
If by "car off" you mean they key is not in the accessory or run position, then connect a relay as follows to switch 12V+ on when the ignition switch is in the off position.
85 to accessory 12V+ 86 to ground 87a to constant 12V+ 30 to what is you want to supply 12V+ when the key is off 87 not used, insulate
Warning! Connecting a relay like this can drain your battery enough to prevent you from starting the vehicle in as little as a day.
I'd need to know more about the LED strip you have, but if it may be possible to just connect the negative side to the GWA (ground while armed) output of the alarm and the other side to 12V+. This would be the preferred method, if possible. ------------- the12volt • Support the12volt.com
Date Posted: April 08, 2014 at 7:03 PM
OK, i will try this again, I have a toyota corolla s and i'm trying to add a light strip to the alarm system. I have tried to put red side to constant power and the ground side of the strip to the ground side of the wire going to the single led that came with the alarm and i get nothing.. So i'm wanting to use a relay it has red,black,white,blue and yellow i want to wire this to turn on when the car is off or when the alarm is armed either or.....Thanks in advance
------------- james
Date Posted: April 08, 2014 at 7:14 PM
I have tried this with no luck, this would be the way i would like to do it but it does not work... I have a clifford remote start and alarm it has a blue and red wire for the oem light in my dash...if you could tell me what i'm doing wrong i would be greatful..
------------- james
Date Posted: April 08, 2014 at 7:18 PM
You do not want to tie into the LED output from the alarm. You need the negative output when armed lead. What Clifford alarm do you have? The more information you provide us, the easier it is to help you. ------------- the12volt • Support the12volt.com
Date Posted: April 08, 2014 at 7:27 PM
Sorry.. it's a 5000 series remote and alarm system model adss5003 start smart.
------------- james
Date Posted: April 08, 2014 at 7:50 PM
OK i got it.. It was the orange wire. you gave me the idea and thank you.. when you said negative when armed i looked it up and found out it's not the led wires.. But now i think i might have a problem... the alarm sets off after 5 mins armed....I will find the problem and fix it i hope but again thank you
------------- james
Posted By: harryharris
Date Posted: April 09, 2014 at 12:34 AM
Clifford LED are about 21/2 volts so without a resistor you might have blown it.
------------- Test before boxing up.
Date Posted: April 09, 2014 at 12:36 AM
This is the way without an alarm:-
Buy a 12 VOLT flashing LED from Radio Shack etc.
Neg wire to the ignition, pos to a constant 12V+ source.
No relay required; will be on until you turn the key.
