viper 3105v doors wont unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136795
Printed Date: May 12, 2024 at 10:23 PM
Topic: viper 3105v doors wont unlock
Posted By: parkertw
Subject: viper 3105v doors wont unlock
Date Posted: June 12, 2014 at 10:34 PM
I'm installing a viper 3105v on a 1992 Toyota Land Cruiser.
I really only care about the keyless entry so I have not hooked up the start kill or siren. With the doors open it will unlock and lock with the remote. Close the doors and it will only lock.
The lights flash when you press unlock and if you reach in and unlock one lock, the remote will unlock the rest.
With the key on and the door closed the remote will unlock and lock.
It only does this when the key is out and door is closed, the remote will not unlock.
Any ideas would be great.
Posted By: howie ll
Date Posted: June 13, 2014 at 12:51 AM
Did you test the vehicle lock and unlock wires before you connected up?
Posted By: kreg357
Date Posted: June 13, 2014 at 4:17 AM
Did you connect the Viper Unlock output to these two Land Cruiser wires?
Info from Ready Remote : Power Unlock Blue / YELLOW & Blue/Orange (-) @ driver door harness in kick *** *** Both wires must be used and diode isolated.
Info from Bulldog Security : POWER UNLOCK BLUE / YELLOW and BLUE/ORANGE (TYPE B) IN DRIVERS DOOR HARNESS Use both, See NOTE #1 Note #1 : for UNLOCK, use BOTH of these wires and DIODE ISOLATE, See DIAGRAM. Link to diagram : https://diagrams.marktoonen.nl/DOWNLOADS/26500_LAND-CRUISER_TOYOTA%20UNLOCK%20DIAGRAM.pdf ------------- Soldering is fun!
Posted By: howie ll
Date Posted: June 13, 2014 at 4:19 AM
I was being lazy but follow Kreg's advice.
Posted By: parkertw
Date Posted: June 13, 2014 at 9:03 AM
Thanks guys, I will try adding the blue/orange wire. I only have it hooked to the blue / YELLOW, it was the only one listed in the wiring info.
I did test the wires first using a power probe and it locked/unlocked fine when grounded.
Posted By: parkertw
Date Posted: June 13, 2014 at 11:47 AM
That worked great.
Thanks again for the help.
