compustar cm 6000 with idatalink
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136941
Printed Date: May 01, 2024 at 5:34 PM
Topic: compustar cm 6000 with idatalink
Posted By: locdo
Subject: compustar cm 6000 with idatalink
Date Posted: July 12, 2014 at 2:38 AM
Hi All,
I am looking to install Compustar CM 6000 to my 2014 STI. I am going to use the two idatalink modules (blade and alca). I saw somewhere and have been looking for about several hours, but can't find it now.
My question is: Which is the easiest and less wiring to use the idatalink blade for the remote start or door locks?
Thanks for the help in advance.
Loc
Posted By: catback
Date Posted: July 12, 2014 at 9:06 AM
It really doesn't matter, pick your poison.
Personally, I'd have the blade doing DL and the alca doing TB because of the KLON programming process and because I associate external bypass modules with doing transponder bypass.
If you go data to data, the wiring is no different either way. If you hardwire the alca then DL on the alca would be alot more wiring.
Posted By: Velocity Motors
Date Posted: July 13, 2014 at 8:21 PM
You will also need the idatalink cable and a user password to perform the Klon
------------- Jeff
