new to alarm viper 5904
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136986
Printed Date: April 29, 2024 at 1:28 AM
Topic: new to alarm viper 5904
Posted By: jundog89
Subject: new to alarm viper 5904
Date Posted: July 23, 2014 at 6:39 PM
Hello, I need help installing my viper 5904 into my recent project a 1979 Chevrolet malibu I have downloaded and printed wiring diagram for the vehicle and installation Manual for the alarm from this website. I have partial of the alarm installed, only part I need help on is the remote start wires. If anybody is willing to do step by step with me I would greatly appreciate it.. thanks in advance
Posted By: freqsounds
Date Posted: July 23, 2014 at 9:06 PM
Is there a specific question you have regarding the wires? I don't have a spare '79 Malibu layin around. ------------- No question is stupid or not worth asking. You were once a noob, right? :)
Posted By: jundog89
Date Posted: July 23, 2014 at 9:19 PM
Oh yea im sorry to post which wires ill post them asap
Posted By: jundog89
Date Posted: July 23, 2014 at 9:59 PM
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT
H3/2 RED / WHITE (87) FLEX RELAY +12V INPUT (30A FUSED)
H3/3 ORANGE (+) ACCESSORY OUTPUT
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)
H3/5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL)
H3/6 RED IGNITION 1 +12V INPUT (30A FUSED)
H3/7 PINK/WHITE (30) FLEX RELAY OUTPUT (car side of ign, acc or starter wire)
H3/8 PINK/BLACK (87a) FLEX RELAY INPUT (key side of ign, acc or starter wire if needed)
H3/9 RED / BLACK ACCESSORY/STARTER RELAY +12V INPUT (30A FUSED)
H3/10 NC No Connection
CAR IGNITION HARNESS
Constant 12V+ Red Ignition Switch Harness
Starter Purple Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White Coil
Brake Switch White Brake Switch
Trunk Pin n/a
Parking Lights Dark Brown Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Driver's Kick Panel
Door Unlock Black Positive Trigger
Horn Wire Black (-) Steering Column
Posted By: howie ll
Date Posted: July 24, 2014 at 12:29 AM
You've actually posted the answer so what's the problem?
H3 Red
H3 RED / White
H3 RED / black ALL to Red constant at ignition harness.
H3 Pink to Pink at ignition harness
H3 Orange to car Orange ditto
Cut Purple from ignition harness, H3 Green to key side, H3 Purple to starter motor side
H3 Pink/white, Pink/black not used.
Install a hood pin provided from a safety angle, you don't want the R/S to start up with someone (you?) working in the engine bay.
Posted By: jundog89
Date Posted: July 24, 2014 at 12:36 AM
Where do I connect H3/2 RED / white?
Posted By: howie ll
Date Posted: July 24, 2014 at 12:37 AM
H2 Violet white to white at coil.
H2 Brown to brake switch white (switched side, goes live when you brake).
H2 Grey. Hood pin.
H2 Blue.Trunk pin, if the factory uses a tilt switch in the light fitting you need to solder between the switch and the bulb terminal.
H1 White. Parking lights set fuse on unit to NEG (see reference chart in the box)to brown.
H2 green door trigger white.
H2 BROWN / black to black horn wire.
Use a 451 module or a pair of relays for the locks, green to light blue, blue to black.
Posted By: jundog89
Ohh nvm lol got it
Posted By: howie ll
Date Posted: July 24, 2014 at 12:39 AM
Answered.
Posted By: jundog89
Date Posted: July 24, 2014 at 12:46 AM
Thanks Howie. I didn't understand where H3-2/7/8/9 would go but u answered them thanks , ill get to it in the A.M.
Posted By: howie ll
Date Posted: July 24, 2014 at 12:50 AM
am? Its 6:50 here now and what's a Chevy?
Posted By: jundog89
Date Posted: July 24, 2014 at 12:53 AM
Its 11pm where I live, what do u mean whats a chevy?
Posted By: howie ll
Date Posted: July 24, 2014 at 12:57 AM
In Europe we only ever rarely see a Corvette (rocking horse etc) and some disgusting POS small Daewoos with Chevy badges on them.
1)Ford Fiesta
2)Ford Focus
3)Vauxhall/Opel Corsa
4)BMW 3 Series
5)VW Golf
Need I say more.
Posted By: jundog89
Date Posted: July 24, 2014 at 1:05 AM
Yea ugly cars we dont have Vauxhall or the opel corsa here , but we do have plenty of corvettes Lamborghini etc here. Google image 1979 Chevrolet malibu thats what the alarm is going in
Posted By: jundog89
Date Posted: July 24, 2014 at 1:06 AM
2door to be exact
Posted By: howie ll
Date Posted: July 24, 2014 at 1:36 AM
You did have Vauxhalls, masquerading as Pontiac LeMans, Saturn Astra built by Daewoo and Buick Regal is the Vauxhall/Opel Insignia.
Posted By: jundog89
Date Posted: July 24, 2014 at 2:01 AM
Not the same looks completely different
