door lock actuator
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137017
Printed Date: May 03, 2024 at 7:54 AM
Topic: door lock actuator
Posted By: hudi
Subject: door lock actuator
Date Posted: July 28, 2014 at 6:27 PM
Does anyone know of a door lock style actuator that when in the locked position, can not be forced open. (not referring to motorized linear actuators, i need it to be controlled by a pulse and do not want someone to be able to "pull up the button" to unlock it)
Thanks,
Hudi
------------- Scorpion
Posted By: blanx218
Date Posted: July 28, 2014 at 8:11 PM
Never seen an actuator like you're referring to but I have disconnected the rod for the manual "button" so that only the actuator would lock/unlock the door
Posted By: catback
Date Posted: July 29, 2014 at 1:31 AM
Either BMW or Mercedes had a system like that where-as once locked with the remote it was impossible to open the door from the inside. This poses obvious safety risks and they have redesigned the system.
If the door you don't want anyone to "force" open has a window or key lock those are the prime weaknesses in your theorized setup.
Posted By: howie ll
Date Posted: July 29, 2014 at 4:03 AM
Deadlocks, actuators made by Spal with either 3 or 6 wires (master).
Had a set once. Pulse extra control wire to deadlock.
