2012 f150 xlt
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137066
Printed Date: May 14, 2024 at 4:35 PM
Topic: 2012 f150 xlt
Posted By: briandit
Subject: 2012 f150 xlt
Date Posted: August 06, 2014 at 9:05 PM
Trying to figure out remote window roll up/down , if i need module? Using Floshlogic Rd bypass, and data port to carlink alsc2. Is their a simpler way using the bcm for triggering
Thanks,
BD
------------- Bdit
Posted By: briandit
Date Posted: August 06, 2014 at 9:08 PM
Correction, flashlogic FLRS01 RS/Bypass
------------- Bdit
Posted By: catback
Date Posted: August 07, 2014 at 1:26 AM
Does the F-150 have euro like comfort closure/opening? If it doesn't roll down or up all the windows automatically already then yes you'll need a window roll up/down module.
Posted By: briandit
Date Posted: August 07, 2014 at 9:21 PM
No, it only has two stage roll up on the front windows, what has me confused is under wiring diagrams it just say motor is part of module, and no color code, the rears do have 5wire codes, but I really just want to vent and or roll down fronts. The module , do you know if it's referring to individual door modules or if there is a way to trigger via can bus or the the smart jack?
------------- Bdit
Posted By: briandit
Date Posted: August 07, 2014 at 9:25 PM
I also have negative programmable Aux outputs on the Carlink, and a few on the flashlogic , I just haven't figured out if I have to go into each door or it can be relay/moduled at the smart jack or somewhere in the drivers or passengers kick panel
------------- Bdit
Posted By: kreg357
Date Posted: August 07, 2014 at 9:40 PM
Looks like you can do it all from inside the drivers door. Gonna need some expensive modules.
Here is the info from Audiovox on the 2012 F-150 :
LF Window Up BLUE/GRAY (REV) MASTER WINDOW CONTROL SWITCH
LF Window Dn YELLOW/VIOLET (REV) MASTER WINDOW CONTROL SWITCH
RF Window Up BROWN / YELLOW (REV) MASTER WINDOW CONTROL SWITCH
RF Window Dn GREEN/ ORANGE (REV) MASTER WINDOW CONTROL SWITCH
LR Window Up BLUE/ORANGE (REV) MASTER WINDOW CONTROL SWITCH
LR Window Dn YELLOW (REV) MASTER WINDOW CONTROL SWITCH
RR Window Up GRAY/VIOLET (REV) MASTER WINDOW CONTROL SWITCH
RR Window Dn BROWN / GREEN (REV) MASTER WINDOW CONTROL SWITCH
------------- Soldering is fun!
Posted By: briandit
Date Posted: August 07, 2014 at 11:28 PM
Thanks Kreg, I'm also an Audivox dealer and could no seem to locate the correct wiring diagram, where did you locate? Looks like the audivox aswrp would work not to bad dealer price
Thanks again
------------- Bdit
Posted By: kreg357
Date Posted: August 08, 2014 at 7:04 AM
Glad to assist. Here is a link to the Audiovox Tech Services WEB site : https://techservices.audiovox.com/Login.aspx
Just to the right of the Login / Password area is a link to register for site access if you're not already set-up.
