2013/2014 bmw starter/imobilizer wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137100
Printed Date: May 04, 2024 at 5:20 AM
Topic: 2013/2014 bmw starter/imobilizer wire
Posted By: ricanraskul
Subject: 2013/2014 bmw starter/imobilizer wire
Date Posted: August 13, 2014 at 2:59 PM
Has anyone ran into or has any suggestions in finding a safe 1 wire method in giving a BMW 3-Series, 6-Series or BMW 5-Series starter kill. Either at the Push-to-Start button or the BCM/ECM/Fuse box. Any one of these vehicles are recent models 2014 or 2013 with a Push-to-Start button system. Thank You!
------------- Good Looking!
Date Posted: August 13, 2014 at 3:21 PM
I forgot to mention, I cannot use resistors to get starter kill either. It has to be 1 wire that when cut, cuts off current to any circuit that starts the vehicle.
Posted By: howie ll
Date Posted: August 14, 2014 at 2:14 AM
BLACK wire in main loom across front of car, top of carpet against bulkhead.
In answer to your next question RED / WHITE
And yes it was my first track + immobilise in a new 2 Series and it took me forever to find it.
Date Posted: August 14, 2014 at 6:32 AM
Greetings howieII,
Thank you for the information above. Would you be a little more specific as to where the BLACK wire is located at (ex. Passenger side, Drivers side)and gauge and or pin information. Also, what is RED / White? is that a different wire that also gives starter interrupt?
Posted By: howie ll
Date Posted: August 14, 2014 at 7:14 AM
Sorry but it was a right hand drive 2 Series I'm in England!
Methinks this will either be in left hand or right hand kickwell, about 12 gauge. Look for a processor box in the following order. Ignition button, ribbon cable into processor, CAS module then the output should have a black wire in its loom.
The RED / WHITE was the only constant (i.e. non dumping/time out after a few minutes) that stayed live. It's the heater blower feed.
Basic info for ALL current BMWs + Mini.
RED = Constant*
BLACK = Starter
Lt. GREEN = Ignition
VIOLET (PURPLE) = ACC
GREY = Lights WHITE and YELLOW Hi and Lo headlights
BROWN = Ground
*Some constants time out. Test after dome lights dim with door open, about 10 minutes.
Plain colours are not fused, secondaries denote fused circuits.
With the ground wires plain brown = direct to ground, brown with a secondary = switched ground, such as parking brake.
Date Posted: August 14, 2014 at 8:06 AM
THANK YOU!!!! again for all of the useful information.
