2013 dodge dart factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137154
Printed Date: April 27, 2024 at 5:09 PM
Topic: 2013 dodge dart factory alarm
Posted By: spartacus12.lg
Subject: 2013 dodge dart factory alarm
Date Posted: August 25, 2014 at 10:50 AM
does anyone know if there is a trigger wire to add a shock sensor to the dart factory alarm.
------------- spartacus12
Posted By: howie ll
Date Posted: August 25, 2014 at 11:46 AM
Highly unlikely all triggers to that alarm should go through the CAN system and factory alarms almost never have aux. sensor inputs. You could tie it to a door trigger.
Except that won't work because again there's no GWA on a factory alarm, so every tome the shock trips it will bring on your dome light.
Date Posted: August 25, 2014 at 11:57 AM
ok thanks
Posted By: tonanzith
Date Posted: August 30, 2014 at 10:00 AM
You could add an aftermarket factory alarm add on system. You would still use your factory remote but it would activate and deactivate new features like shock sensors etc when you lock and unlock your system via factory remote.
------------- Gary Sather
Posted By: howie ll
Date Posted: August 30, 2014 at 10:02 AM
Good point try Viper, 3300 series, siren, optional sensors +, - and 2 CAN connections.
Date Posted: September 01, 2014 at 4:33 PM
Not really a viper fan and will only use it if there is nothing else. Are there any other factory after markets that you would recommend? And are they installer friendly?
Posted By: catback
Date Posted: September 01, 2014 at 5:18 PM
They make aftermarket shock sensors for OEM alarms as I recent found out, the 504K being one of them. You can go that route as well. Myself, I wouldn't spend the money for just a shock sensor upgrade.
Posted By: howie ll
Date Posted: September 01, 2014 at 5:32 PM
X 2 with Catback rather have a dual zone prox with warn away any day.
Either way you need to relay isolate either or both trigger wires so it doesn't work with the ignition on.
I've installed loads of 3303s, reliable alarm with a built in shock sensor
Frankly a good installer should be happy with any product from Avox/Code/Prestige, Comp, or DEI.
We install about 10 5X04/6 a week here in the UK, never had a brain go down on us yet.
Posted By: i am an idiot
Date Posted: September 01, 2014 at 6:15 PM
It does have a hood pin. You should be able to add shock to this.
Hood Trigger PURPLE / DK BLUE (-) BCM UNDER DRIVERS DASH BLACK 60 PIN PLUG
Date Posted: September 05, 2014 at 11:20 PM
Thanks for all the great info.
