1998 gmc jimmy sls door lock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137272
Printed Date: April 28, 2024 at 2:37 PM
Topic: 1998 gmc jimmy sls door lock
Posted By: omar252
Subject: 1998 gmc jimmy sls door lock
Date Posted: September 16, 2014 at 3:13 PM
I have a 1998 gmc jimmy without factory keyless entry I am trying to install an aftemarket keyless entry and was wondering does this vehicle need to relays in order to get the doors to lock and unlock?
Posted By: i am an idiot
Date Posted: September 16, 2014 at 3:29 PM
Audiovox has this info.
Power Lock LIGHT BLUE (+) AT MODULE TO RIGHT OF GAS PEDAL UNDER CENTER OF DASH
Power Unlock WHITE (+) AT MODULE TO RIGHT OF GAS PEDAL UNDER CENTER OF DASH
I do not know what kind of keyless you are using, but if it is an audiovox unit. You can connect the unlock wire to the lock wire of the vehicle, and connect the lock wire of the device to the unlock wire of the vehicle and you should not need a relay.
Posted By: omar252
Date Posted: October 03, 2014 at 11:17 AM
I am using a viper keyless entry system would i need the relays?
Date Posted: October 14, 2014 at 10:42 AM
If the unlock wire of the viper has positive voltage on it during a lock cycle, then you will not need the relay. If it does not go positive you will need to use relays.
Posted By: howie ll
Date Posted: October 14, 2014 at 12:02 PM
If the Viper has blue/black, GREEN/ black, WHITE/ black, BROWN / black, violet/black and violet, then relays aren't required.
