idata modules
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137283
Printed Date: May 05, 2024 at 11:44 AM
Topic: idata modules
Posted By: ziggyb222
Subject: idata modules
Date Posted: September 18, 2014 at 1:11 PM
I have used some of these modules in the past. I am doing a 08 Malibu 2-way remote start. I purchased a ADS TB...by mistake. I wanted the ADS DL. The one I want to buy says in the description it is a ADS-DL (black)...what does this mean? Can I download the proper firmware for the 08 Malibu and do locks and bypass??? Thanks for you time!!!
Posted By: tonanzith
Date Posted: September 18, 2014 at 2:15 PM
The ads do will do everything you need. Door locks and immobilizer bypass for your vehicle.
------------- Gary Sather
Date Posted: September 18, 2014 at 2:16 PM
Sorry. The ads dl I meant. Dang spell check.
Posted By: shafferny
Date Posted: September 21, 2014 at 10:23 AM
ADS-TB = Transponder Bypass ONLY
ADS-DL = Door locks and immobilizer bypass
ADS-ALCA = Door locks and immobilizer bypass
That's the way I understand it.
Depending on your year/make/model you may be able to use the ADS-DL,however, the ADS-ALCA has greater year/make/model coverage. Someone please correct me if I'm wrong.
