2010 ford edge and 535t
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137285
Printed Date: May 02, 2024 at 2:41 AM
Topic: 2010 ford edge and 535t
Posted By: spartaman10
Subject: 2010 ford edge and 535t
Date Posted: September 18, 2014 at 5:53 PM
Hello, I have a2010 Ford edge with Viper 5704. Tried to install 535t on front two windows. Passenger side goes fully up when armed, and vents via aux. The issue is the drive window. Looking for some help with the drive window due to the auto circuit. The driver window goes up a little bit on arm, and vents half of what passenger does via aux. I believe my problem is within the factory auto down circuit.. any help would be greatly appreciated. Thank you.
Posted By: tonton1981
Date Posted: March 17, 2015 at 1:56 AM
your switch and motor wires are crossed at the 535t harness
example:
switch up side of door to switch down side of 535t
switch down side of door to switch up side of 535t
swap those around
do same for motor up/down wire
then try again
should be ok :)
Tony
Posted By: xraytedrick
Date Posted: June 30, 2015 at 12:56 PM
Hello, did you get this to work. If so, how? Thanks
------------- Rick
