wiring diagram for 2014 cross trek
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137367
Printed Date: May 10, 2024 at 12:16 AM
Topic: wiring diagram for 2014 cross trek
Posted By: ccaudio
Subject: wiring diagram for 2014 cross trek
Date Posted: October 02, 2014 at 10:45 PM
Looking for a wiring diagram for this year car and if it needs any bypass modules. Thank you.
Posted By: catback
Date Posted: October 03, 2014 at 12:56 AM
Without Smartkey
12volts white (common 40A) + ignition switch, white 8 pin plug, pin 4
Starter BLACK/ white + ignition switch, white 8 pin plug, pin 3
Second Starter white + ignition switch, white 8 pin plug, pin 7
Ignition green + ignition switch, white 8 pin plug, pin 1
Second Ignition blue + ignition switch, white 8 pin plug, pin 6
Third Ignition N/A
Accessory yellow + ignition switch, white 8 pin plug, pin 2
Second Accessory N/A
Keysense BLACK/ white + key switch, white 2 pin plug, pin 2
Power Lock lt. GREEN/ black - driver kick, white 28 pin plug, pin 15
Power Unlock blue/black - driver kick, white 28 pin plug, pin 16
Lock Motor RED / green 5 wire driver kick, white 28 pin plug, pin 17
Unlock Motor lt. green 5 wire driver kick, white 28 pin plug, pin 18
Parking Lights+ BLACK/ white + dash fuse box, white 20 pin plug, pin 12
Parking Lights- BLACK/ blue - headlight switch, white 20 pin plug, pin 18
Hazards green - left of steering column, white 17 pin plug, pin 10
Turn Signal(L) WHITE/ red + dash fuse box, white 20 pin plug, pin 20
Turn Signal(R) gray + dash fuse box, white 20 pin plug, pin 3
Reverse Light BROWN / yellow + passenger kick, white 20 pin plug, pin 4
Door Trigger blue/orange to blue/white - driver kick, white 10 pin plug, pin 8
Dome Supervision GREEN/ YELLOW - left of steering column, white 12 pin plug, pin 9
Trunk/Hatch Pin yellow/blue - BIU behind dash fuse box, black 35 pin plug, pin 33
Hood Pin yellow/black (with remote start only) - Remote Start Module above brake pedal, white 4 pin plug, pin 4
Trunk/Hatch Release GREEN/ red (rear handle switch) - BIU behind dash fuse box, black 35 pin plug, pin 10
Power Sliding Door N/A
Factory Alarm Arm (arms on lock with driver door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (transponder and ignition)
Tachometer white, BLACK / YELLOW, BLACK/ red, or BLACK/ blue ac passenger rear of engine, black 54 pin plug, pin 54, 53, 52, or 51
Wait to start N/A
Brake Wire brown + dash fuse box, white 20 pin plug, pin 15
Parking Brake gray - driver kick, white 24 pin plug, pin 16
Horn Trigger red - horn switch, white 14 pin plug, pin 9
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Modules: Not Available
Posted By: catback
With Smartkey
12volts white (common 40A) + relay holder behind dash fuse box, white 44 pin plug, pin 29
Starter BLACK/ white + relay holder behind dash fuse box, white 44 pin plug, pin 2
Second Starter BLACK/ white (SS1); BLACK/ orange (SS2) - push button ignition switch, white 14 pin plug, pins 7, 2
Ignition green + dash fuse box, rear, brown 9 pin plug, pin 8
Second Ignition blue + dash fuse box, rear, brown 9 pin plug, pin 3
Third Ignition N/A
Accessory blue / YELLOW + dash fuse box, rear, brown 9 pin plug, pin 7
Keysense N/A
Hood Pin yellow/black (with remote start only) - Remote Start Module conn above brake pedal, wht 8 pin plug, pin 5
Disarm No Unlock (smart key and ignition)
Tachometer green ac Keyless Access Module right of BIU, white 18 pin plug, pin 17
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Posted By: catback
Date Posted: October 03, 2014 at 1:01 AM
It does require an immobilizer bypass.
Posted By: ccaudio
Date Posted: October 03, 2014 at 11:17 PM
Can I just use a 791 bypass module. It has a smart key.
Posted By: catback
Date Posted: October 04, 2014 at 2:11 AM
If you want to give up a key and can make the loop setup work yes you can use a 791 or other universal bypass. The preferred method is to use a bypass unit like an idatalink alca that when paired with a compatible alarm can save lots of time and wiring on an install as well as save the owner from losing a key to a universal bypass.
Posted By: ccaudio
Date Posted: October 05, 2014 at 8:47 PM
The only problem I have is I don't have a computer to download software. Usually I would use a pk all or something you don't have to hook up to computer.
Posted By: catback
Date Posted: October 05, 2014 at 11:15 PM
And that's why the bypass manufacturers have gotten into using smartphones to do the programming.
Honestly, the computer age is where it's at, especially with these new "smartkey" PTS cars. It can save alot of wiring or down right make it possible to put in a remote start.
