98 civic viper 5601 no start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137477
Printed Date: April 28, 2024 at 9:43 PM
Topic: 98 civic viper 5601 no start
Posted By: jcrak_78
Subject: 98 civic viper 5601 no start
Date Posted: October 19, 2014 at 3:03 AM
Hi guys, I'm having a problem with an install of a viper 5601.the car had a python 650 installed I used the same door lock, lights, ground, and siren wires. I then ram all the H3 harness wires. Everything for the alarm works fine, but when I try starting with the remote all I get is clicks from the "brain" but the car does nothing. If anyone has any prior experience with this and can help me out I'd appreciate it thanks in advance
Posted By: howie ll
Date Posted: October 19, 2014 at 6:28 AM
List your connections and to where.
Posted By: jcrak_78
Date Posted: October 19, 2014 at 10:49 AM
Hey thanks here's what I have
main harness (H1)
RED / white going to blue/black on car
white going to RED / black on car
green Going to light GREEN/ red on car
brown to siren
Red (fused) to solid white at column harness
all above are tapped into harness that plugs into blue connector attached to fuse panel except siren and constant
Remote start harness (H3)
Solid red and RED / black go to solid white at column
Purple to left side of BLACK/ white at column
Green to right side of same BLACK/ white as above
orange goes to WHITE/ black at column
RED / white goes to yellow at column
Pink goes to BLACK / YELLOW at column
pink/white & pink/black go nowhere
Harness (H2)
Brown to GREEN / WHITE at brake
Gray to hood pin (not hooked up yet)
PURPLE / white going to tach wire at small plug by driver side corner of firewall
Posted By: jcrak_78
Date Posted: October 19, 2014 at 12:29 PM
Nevermind !!! Just found the problem... I never grounded the neutral safety wire. I did that and now it works fine
Posted By: howie ll
Date Posted: October 19, 2014 at 5:05 PM
And your RED / white at H3 should also go to white, pink/white to yellow.
You beat me to the BLACK/ white!!
Posted By: jcrak_78
Date Posted: October 20, 2014 at 8:47 AM
Thanks for your time and expertise !
