2015 subaru legacy flashlogic issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137760
Printed Date: May 05, 2024 at 8:35 AM
Topic: 2015 subaru legacy flashlogic issues
Posted By: dkaar
Subject: 2015 subaru legacy flashlogic issues
Date Posted: November 22, 2014 at 12:50 PM
The Flashlogic wiring information is incorrect for the 2015 Subaru Legacy. The attached file shows my situation. The IMMO Data wire is not there and the security light wire is incorrect. Can anyone lead me to the correct wires or on how to test the IMMO wire?
Posted By: pentavolvo
Date Posted: November 22, 2014 at 6:29 PM
I've given up on using flash logic on a newer subaru last 2 I did nothing matched and finally just did a key in box
Posted By: shadowinfector
Date Posted: December 02, 2014 at 9:12 PM
I am having the same issue......no immo data wire there.... did you get this vehicle done?
Posted By: tedmond
Date Posted: December 03, 2014 at 12:05 AM
usually the bcm/biu are upside down, while in the guide its other way around.
------------- Ted
Compustar Expert
Date Posted: December 03, 2014 at 10:13 AM
so i just finished the install, i went straight to the ecu on the passenger side, lower plug, pin 38 Data Bus - WHITE/ blue
Date Posted: December 03, 2014 at 10:15 AM
so i just finished the install, i went straight to the ecu on the passenger side, lower plug, pin 38 Data Bus - WHITE/ blue , on pzev vehicles there is NO wire at the plug on the tech sheet from idatalink. You need to go straight to the ecu on pass side engine compartment.
