control center wont chirp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137785
Printed Date: May 07, 2024 at 12:10 PM
Topic: control center wont chirp
Posted By: hunterhyatt3
Subject: control center wont chirp
Date Posted: November 24, 2014 at 5:44 PM
I recently installed my viper 5704 and everything works great, except the remote start. My lcd remote was displaying remote start error. The parking light would flash 7 times indicating a manual mode error. After reading numerous forums over the past few days attempting to fix the problem, I have learned that these systems come from the factory in manual transmission mode and that to fix this requires the following procedures
1 ) turn car to ignition then off.
2) hold valet button ( shpuld be part of antennae) until it chirps 3 times
3)Release valet push once release and then push and hold . On remote hit lock , it will chirp 2xs .
4) turn car to ignition then off and it should remote start
This would work except when I go to hold the valet button it will never chirp no matter how long I hold it, all that happens is valet mode turns on when I release it
Any advice? Any wires to check? Any adjustments to my procedure? Help.
It's installed on a 97 tahoe 4-door
Posted By: smokeman1
Date Posted: November 24, 2014 at 9:32 PM
1 Are your door trigger wires connected? H2/6 or H2/12? If so a door needs to be open before you turn ignition on then off. If not connected ground one of them.
2 the control center itself does not chirp. The siren does or the horn. If they are not connected you won't hear any chirps.
------------- When all else fails, Read the Instructions
Posted By: howie ll
Date Posted: November 24, 2014 at 9:56 PM
Actually only ground the green H2. The violet should go to a 12Volt+ constant, either or. Other wise exactly as Smokeman told you.
Posted By: thespinman82
Date Posted: November 25, 2014 at 6:30 PM
Dude, I have a Viper 4704v and am having the same exact issue! Holy *hit I finally found someone with the same issue. I noticed to beep or chirp from anywhere. I will also try this fix. Thanks for the info fellas! I will let you know what happens.
Date Posted: November 26, 2014 at 4:52 PM
My siren is connected and it chirps when locked/unlocked. The green wire h2/6 is connected to the negative door trigger wire behind the headlight switch I connected the violet wire h2/12 to a constant 12v source. I locked the truck, unlocked it got in, left the door open, turned the key on then off, within about 3 sec held the valet button and still no chirp.
Does anybody have any other suggestions?
Date Posted: November 26, 2014 at 5:35 PM
OK. This is what I did to get to automatic. Instead of chirps I get horn beeps which I use to listen to the signals for the programming. I also have the door triggers hooked up too and tested. I followed the man/auto directions you have and just took my time with it. It took me several times to change it too auto but it worked. Just make sure you have the HORN wire from the viper unit hooked to the actual HORN switch and you will get your programming signals that you need to listed for and follow.
