2014 BMW M3 Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137835
Printed Date: May 12, 2024 at 10:37 PM
Topic: 2014 BMW M3 Remote Start
Posted By: ceasar326
Subject: 2014 BMW M3 Remote Start
Date Posted: December 01, 2014 at 8:46 PM
Ok guys so it's been a while since I've post anything. And need some assistance with a remote start. Got a 2014 BMW M3 from a customer and can't find a unit that would work for that vehicle. Was hoping that ADS-BM1 from Idatalink would work but no luck. Has anybody done a remote start on this kind of vehicle? It has the smart key I believe and whant to do a 2way unit. Thanks in advance.
Posted By: shark mobile
Date Posted: December 01, 2014 at 9:55 PM
Niche vehicles almost always need a key wrap w/ transponder ring...this is a big sacrifice for the customer but the only way to provide a stable transponder. It's a relatively simple install with the use of a relay and some thin wire, and of course the customers extra key or valet key. Hope that helps.
------------- Solder, tape, repeat!
Date Posted: December 01, 2014 at 10:12 PM
Thanks for the quick response. I did a 2001 BMW 325i with key in a box a while back. But I don't understand how this 2014 BMW m3 will work the same if it's a push to start. Also if it did what wiring diagram could I use since I only got access till 2010 diagrams. Does any body have a wiring diagram for that vehicle?
Posted By: howie ll
Date Posted: December 02, 2014 at 6:00 PM
Try Xpresskit Euro section, my other half does the late BMWs. He uses a DB-ALL2 key wrap as explained above and an adaptor cable from the PTS to the DB.
Euro cars especially the Germans have extra immobilisation hence the need for a key.
The Ford Fiesta for example, Euro and US versions all made in Spain but the Euro version needs a key wrap!
Yet I've installed to UK made Hondas and Toyotas and done the by-pass via data!
From what I've gathered F series BMW don't need K1BMW, only a DB-ALL.
Posted By: tedmond
Date Posted: December 02, 2014 at 9:24 PM
DBALL2 doesn't work with the M3 made here in canada, only in the euro market due to different can network. theres a reason why idatalink, fortin dont have coverage yet. due to the incompatibility thats why xpresskit doesn't list it under cad/usa as a solution.
Personally tried and tested on my own 14 F30/F31 M3
------------- Ted
Compustar Expert
Date Posted: December 02, 2014 at 10:03 PM
Thanks guys for the input. I had the customer bring in the car for a check up and looked at the information sticker on the side of the door. Where the vin # and all other information is located. And notice that it says 5/13. But checked vin # for year and shows for 2014. So my question now is do u guys think I can still use the Idatalink ads-bm1 and flash it for 2013 even though vin says 2014.
Posted By: tedmond
Date Posted: December 02, 2014 at 11:45 PM
give it a shot and see.
------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: December 03, 2014 at 2:34 AM
13 and 14 should be the same.
The electrical systems stay much the same, E46 and E90 shared many similarities.
Date Posted: December 03, 2014 at 8:49 AM
Yea that's what I thought. I got it scheduled for Friday and let u guys know how it goes. Thanks for the help and on till Friday.
