2012 wrangler clutch bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137871
Printed Date: May 15, 2024 at 9:17 AM
Topic: 2012 wrangler clutch bypass
Posted By: tek1001
Subject: 2012 wrangler clutch bypass
Date Posted: December 04, 2014 at 7:36 PM
Need to know how to bypass the clutch switch on my 2012 jeep wrangler so I can use my remote start I am using a crimestopper LC-1 with fortin EVO-ALL and the THAR-CHR5.
------------- tek1001
Posted By: tedmond
Date Posted: December 05, 2014 at 11:00 AM
yellow/orange (-) @ clutch switch.
send negative start signal from unit to this wire.
------------- Ted
Compustar Expert
Posted By: tek1001
Date Posted: December 08, 2014 at 9:33 AM
check engine light came on after remote start read some where about interrupting a green and orange wire but still will not work unless clutch is push down
Posted By: tedmond
Date Posted: December 08, 2014 at 1:41 PM
May need to interrupt dk. GREEN/ orange, pin 1 of the clutch switch during remote start to avoid check engine light.
use a relay
85 - ground when running or 2nd ignition output (-)
86 - constant 12v
cut the dark GREEN/ orange wire in half
87a - connect one of cut side to this (away from clutch)
30 - connect other side of cut wire to this (towards clutch switch)
------------- Ted
Compustar Expert
Posted By: BNLUIS
Date Posted: December 09, 2014 at 3:51 PM
------------- Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: shark mobile
Date Posted: December 09, 2014 at 7:46 PM
Just did one and both luis and Ted are correct...without the relay it's going to throw codes ;). Follow the diagram and you'll be fine.
------------- Solder, tape, repeat!
Posted By: tmp215
Date Posted: January 21, 2016 at 9:52 PM
i am also installing a remote start on my 2014 wrangler. i am using a crimestopper rs4g5 remote start. on the module it self, there are connections for 12v,ignition, starter, accessory . all need to be connected to the vehicle. the part that is confusing me is the wiring diagram that i have seen for the jeep. It says that the accessory wire is the same as the starter wire . so does that mean i would connect both starter and accessory wire together ??
any help is appreciated
