dodge dakota viper 5706v
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137893
Printed Date: May 17, 2024 at 7:38 AM
Topic: dodge dakota viper 5706v
Posted By: onthebrink18
Subject: dodge dakota viper 5706v
Date Posted: December 07, 2014 at 5:00 PM
I am attempting to install my first remote start system into my 2008 Dodge Dakota. The remote starter/alarm is the Viper 5706V, and will be connected using the DBALL2. I think that I have all of the connections figured out, but I would like a double check from the local experts posted_image. I have read about issues in using the D2D method and I have decided on using W2W. The wires that I am most confused about are the 10-pin heavy gauge wires on the Viper module.
The dark gray lines are not connected.
posted_image
posted_image
posted_image
Posted By: kreg357
Date Posted: December 07, 2014 at 5:28 PM
Looks good!  Only one oversight.  You will need to connect the thick Pin 5 Red and Pin 2 RED / Black wire to +12V constant.
I wouldn't use the +12V at the ignition switch harness.  It would be better to get all your power from here :
12volts    Red  (+)    battery or IPM **
** The IPM (Integrated Power Module) is in the engine compartment, on the driver fender.
Here are the wire color of the CAN wires at the igntion harness :
CanHigh      pin 6 WHITE/ Orange (DATA)         @ Ignition switch
CanLow       pin 7 White (DATA)          @ Ignition switch
Date Posted: December 07, 2014 at 6:18 PM
Thank you for the fast replyposted_image. I will make those changes.
Would it make sense to use a pick and remove the unused pins from the connector housing, or should I leave them in for proper connector retention and just tape the ends off?
Posted By: kreg357
Date Posted: December 07, 2014 at 6:32 PM
De-pinning is a pain but makes things look neat.  The down side is that if you ever need to make a change, you have nothing to work with.  I make a compromise between the two and just cut the unused wires to a bit less than 2 inches, then group them together with heat shrink tubing that covers the ends and, after heating, holds them securely.  If I ever need to make a change, I have enough wire to solder on a length of the correct color / gauge wire.  Think most installers have a large bag of trimmed ends for adding length to any wire during an install to reach the destination.
Date Posted: December 07, 2014 at 6:38 PM
That sounds like a good compromise.
