dball2pro remote pairing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137944
Printed Date: April 28, 2024 at 5:08 PM
Topic: dball2pro remote pairing
Posted By: chek
Subject: dball2pro remote pairing
Date Posted: December 11, 2014 at 6:29 PM
I installed a dball2pro in a 2014 Toyota Camry....every thing was groovy until I realized I don't know how to pair the remote......it came as a kit with antenna and antenna cable....anybody??
Posted By: chek
Date Posted: December 11, 2014 at 8:47 PM
Anybody??
Posted By: smokeman1
Date Posted: December 11, 2014 at 9:04 PM
Maybe you could tell us what the kit is? Model number. what came in the kit.
------------- When all else fails, Read the Instructions
Posted By: tedmond
Date Posted: December 11, 2014 at 9:15 PM
determine which remote you have, go to xpresskits.com look for the xl202 guide for your remote, program away
------------- Ted
Compustar Expert
Posted By: chek
Date Posted: December 12, 2014 at 5:37 AM
It didn't come with a xl202, would I use the program button on the dball2pro the same way?
Posted By: tedmond
Date Posted: December 12, 2014 at 8:21 AM
if it didnt come with the xl202, the dball2pro must be flashed to allow a rf kit. remote progrmming comes with the rf kit
------------- Ted
Compustar Expert
Posted By: chek
Date Posted: December 12, 2014 at 10:50 AM
I think I'm confusing the issue a bit. The dball2pro doesn't need a xl202 it just needs an antenna and matching remote. When I flashed the module is WAS able to choose the type of remote I'm using but now it still needs to learn the unique code for that exact remote. I know with the xL202 has you hold in the programming button while holding in on certain buttons on the remote in order to pair the two together.....that procedure doesn't seem to work on the dball2pro :(
Date Posted: December 12, 2014 at 11:23 AM
Does the antenna cable plug into the DB-ALL? I don't think i have seena setup like that. Got a photo you can post of this kit?
Posted By: chek
Date Posted: December 12, 2014 at 12:11 PM
Yes it does....it's DEI's new digital remote start system. It's a dball2pro with antenna/remote kit. The pro part is what's confusing people I think....Directed Electronics Inc Python 4211P Xpress Start 1 Button 2-Way Remote Starter is its official name.....I'll try to post a picture
Posted By: chek
Date Posted: December 12, 2014 at 2:02 PM
Sorry, it won't let me post photos
Posted By: chek
Date Posted: December 12, 2014 at 2:34 PM
Got it!!
Open door
Turn ignition on
Press and release valet button
Press and hold valet button
Press lock ( or start button on one button remotes) for one second
Release valet and turn ignition off
Done!!
I was trying to use the dang program button intstead of valet....don't I feel dumb...
Anyway thank you so much guys!!! Love this site!!
Posted By: skyfox16
Date Posted: December 23, 2014 at 8:51 PM
I am trying to do this same setup. I have the dball2pro installed and the 3x lock start works on the OEM remote. I wanted to add an RF kit but i had a couple questions.
Did your antenna plug into the green port on the dball2pro?
What RF kit do you have? is your remote 1 way or 2 way?
Posted By: skyfox16
Date Posted: December 23, 2014 at 8:53 PM
Also, did you plug the valet button into the black port on the dball2pro? I think there is only one port that it fits into is this correct?
Posted By: chek
Date Posted: December 23, 2014 at 9:13 PM
Any DEI RF kit should work. Mine is a two way, one button Python remote. The green plug went to the green port on the dball2pro and the same end as the green plug had a black socket on the antenna cable for the valet switch. If you have an antenna with a valet button built in then you won't need a separate valet button. I believe the two pin black port on the dball2pro itself is for the LED light, which I didn't use because it's only needed if you're setting it up as an alarm system too. Be sure when you flash the dball2pro you pick the RF kit remote you will be using from the list.
Posted By: chek
Date Posted: December 23, 2014 at 9:16 PM
The valet switch does not plug into the dball2pro even though it looks like it fits. At least mine didn't.
Posted By: skyfox16
Date Posted: December 23, 2014 at 9:20 PM
Ok thanks for the info.
Where did you get your kit from? I was trying to make my own and I have the one button 2 way Python remote but I can't figure out the programming part.
Posted By: chek
Date Posted: December 23, 2014 at 9:28 PM
You need antenna 6212T to go with that remote. Then just plug it into the dball2pro, open the door, turn key ON, press and release valet button, press and hold valet button and while holding press the one button remote, then release valet button. Done.
Posted By: skyfox16
Date Posted: December 23, 2014 at 9:48 PM
Ok, i have that antenna, but the cable i have only has a black connector that goes into the antenna and then a white connector that looks like i would plug in where you plug the xk loader 2 into the dball2pro.
it seems like your antenna cable is different because i dont know where to plug the valet switch into (it has a blue connector with two wires).
Posted By: skyfox16
Date Posted: December 23, 2014 at 10:00 PM
my cable and antenna are like this:
https://www.dropbox.com/s/bm96fj54atfh2qq/2014-12-23%2010.57.44%20pm.png?dl=0
i know they make a white plug to green plug adapter i could get so it will plug into the dball2pro, but then I'm still not sure where to plug in the valet switch to program.
Did you buy yours all as a kit? or did you buy a certain RF kit?
Posted By: chek
Date Posted: December 24, 2014 at 4:15 AM
That antenna should have another cable with it. Mine came as a complete kit Python 4210p but they have a bunch of similar units 4X10 where the X indicates various numbers. The 4 means it's a remote start only, the 2 means it's a 2 way system the 10 is the all in one platform.
They also make a 5x10 system just meaning it's also an alarm.
Posted By: chek
Date Posted: December 24, 2014 at 4:22 AM
Sorry 4211p is what I have but 4210p, 4710p, 4211p are all the same basic kits that just have different RF kits that come with it ..... Some are one way, 2 way LCD, two way LED and so forth. They all are complete kits based on the dball2pro.
