Print Page | Close Window |
2003 silverado lt k1500 with valet 561rPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137950 Printed Date: May 02, 2024 at 3:08 AM Topic: 2003 silverado lt k1500 with valet 561r Posted By: ransdell2 Subject: 2003 silverado lt k1500 with valet 561r Date Posted: December 12, 2014 at 12:43 PM I am installing a Valet 561R with the Xpresskit GMDLBP set to Type 4 in a 2003 Chevy Silverado LT. So far I've had almost zero luck with the installation. All of wires are connected as listed below. I did a lot of searching on the interwebs for information, and used the post at https://www.the12volt.com/installbay/forum_posts.asp?tid=137674 as my primary guidance, the main difference being that the poster used the Avital 4103 and I'm using the Valet 561R. I also found a post on a R/S installation on a 2003-2006 Denali that was similar, but used a different bypass.
This is what's happening when I try to use the remote start: Door lock /unlock button - the R/S will click once on the first press, then twice on the second. The door locks don't do anything. * button - nothing at all Aux button - nothing at all GMDLBP - programmed to Type 4, flashing four times. Tach learning - the program button wasn't working, so I cut it off and an shorting the wires together to simulate pressing the button. When I try to learn the tach with the truck running (within 5 seconds of starting), the LED on the Valet will blink about every three seconds for about a minute, then go blank. I thought the GMDLBP would be able to provide tach info from the OBDII wire, but now I'm wondering if I need to connect the Valet's tach input wire (H2/2) to the vehicle's tach wire. Any suggestions? I'm also starting to wonder if the R/S brain is dead, but the LED light during attempted tach learning makes me think otherwise (but the LED never lights up otherwise). I've spent a lot of time working on this, and am stuck. I have relays available for use, but don't know if or where to use them. Thanks in advance! W2W connections for 2003 Silverado w/Auto trans using GMDLBP bypass module and Avital 4103 R/S Valet 561R. Valet 561R H1/1 LIGHT GREEN/ BLACK FACTORY ALARM DISARM Not Used H1/2 GREEN / WHITE FACTORY REARM Not Used H1/3 YELLOW (+) IGNITION OUT (TO ALARM) Not Used H1/4 WHITE/ BLUE (-) ACTIVATION INPUT Not Used H1/5 GRAY/BLACK (-) WAIT TO START INPUT Gray/Black (-) BCM, brown plug, pin B2 (Using this for (-) parking lights…?) H1/6 WHITE/ RED (+) ACTIVATION INPUT Not Used H1/7 RED / WHITE CHANNEL 2 (VALIDITY ONLY) Not Used H1/8 BLACK GROUND H1/9 WHITE (+/-) LIGHT FLASH Set Jumper to (-) gray/black (-) BCM, brown plug, pin B2 Not used? H2/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT Chassis Ground ( if Auto Trans ) H2/2 VIOLET/WHITE TACHOMETER INPUT WIRE white (ac) instrument cluster, gray 24 pin plug, pin A5 Not used - Does the GMDLBP get the tach info from the OBDII pin 2? H2/3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE white (+) brake switch H2/4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE to 4103 kit supplied hood pin Grounded (haven't run wires through firewall yet) H2/5 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOG Not Used 4-pin satellite harness diagram 1 BLUE STATUS OUTPUT GMDLBP Brown wire 2 ORANGE (-) ACCESSORY OUTPUT To Pin 85 of external ACC2 Relay - Not Used? 3 PURPLE (-) STARTER OUTPUT Not Used 4 PINK (-) IGNITION OUTPUT Not Used Heavy gauge relay wiring diagram 1 PINK (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT pink (+) @ ignition harness 2 PURPLE (+) (30 AMP) OUTPUT TO STARTER Yellow (+) @ ignition harness 3 ORANGE (+) (30 AMP) OUTPUT TO ACCESSORY Orange (+) @ ignition harness 4 RED (+) (30A) HIGH CURRENT 12 INPUT Red (+) @ ignition harness 5 PINK/WHITE (+) PROGRAM FOR ACC OR IGN White @ ignition harness Verify 4103 Menu 2, Item 6 to Opt 1 6 RED (+) (30A) HIGH CURRENT 12V INPUT RED / White @ ignition harness Door lock harness, 3-pin connector 1 BLUE (-) UNLOCK OUTPUT GMDLBP Blue wire 2 EMPTY NOT USED 3 GREEN (-) LOCK OUTPUT GMDLBP Green wire None of this was used - Extra 30/40 Amp SPDT relay for ACC2 circuit Relay Pin 85 to Avital 4103 Orange (-) Accessory Output Relay Pins 86 and 87 to Silverado RED / White +12V constant @ ignition switch harness with 25 Amp fuse Relay Pin 30 to Silverado Brown (+) Accessory2 wire @ ignition switch harness GMDLBP Brown to 4103 Blue (-) Status Output Green to 4103 Green (-) Lock Output Blue to 4103 Blue (-) Unlock Output Violet/White H1/1 LIGHT GREEN/ BLACK FACTORY ALARM DISARM Note : Connect this wire to disarm wire from remote car starter ONLY if the OEM alarm sounds once when remote starting vehicle…? Violet to Silverado Violet wire at Pin 2 of OBD2 plug Pink/White Not Used Pink Not Used Orange Not Used Red to 4103 thick Red +12V constant Black to 4103 H1/8 Black Chassis Ground Programming : The GMDLBP comes set to Type 1 platform. You must change this to Type 4 for your truck. See Page 4 of the install guide for the directions. 1) To change the Vehicle Platform Setting, press and release the program button until the LED flash rate is the same as the TYPE of vehicle required. The number of flashes from the LED confirms the Vehicle Platform Type that has been selected. Ex: 1 flash = TYPE 1, 2 flashes = TYPE 2, and so on... EX: If TYPE 4 is required: Please note the module is already in Vehicle Platform TYPE 1. Press the programming button to advance to the next TYPE selection (3X times in total). The LED will then flash 4 times to confirm TYPE 4 selection. 2) Once Vehicle Platform Type has been selected, press & hold program button until LED blinks once to confirm setting is saved & ready to program to vehicle. 3) Release programming button and the LED will come ON solid. 4) Start the vehicle with the ignition key: The LED will turn off confirming the GMDLBP is programmed to the vehicle. Replies: Posted By: ransdell2 Date Posted: December 23, 2014 at 7:01 PM 277 views and no replies? Everything I've read says this is a simple truck to do a remote start on. C'mon, somebody help me...
Posted By: chev104275 Date Posted: December 24, 2014 at 5:08 AM H1/5 isn't used for lights it's used for a diesel wait to start light.
H2/4 can't be grounded the remote start won't work it thinks the hood is open Did you set the gmdlbp to type 4 ? ------------- If i Can't Install it I Don't need it Joe Posted By: kreg357 Date Posted: December 24, 2014 at 7:18 AM If you are using what you posted to make your connections, it is very confusing. Seems to be a collage of several H1/1 LIGHT GREEN/ BLACK FACTORY ALARM DISARM Might need to connect to GMDLBP Violet/White 1 BLUE STATUS OUTPUT GMDLBP Brown PINK (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT Silverado Pink @ main ignition harness Door lock harness, 3-pin connector H2/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH Chassis Ground for Auto Trans Extra 30/40 Amp SPDT Relay for ACC2 GMDLBP * Set to Type 4 IMPORTANT: DO NOT CONNECT VIOLET DATA OUTPUT WIRE OF INTERFACE MODULE TO VEHICLE DATA WIRE (PIN 2) Test all wires with a DMM and solder all connections for a safe and long lasting install. ------------- Soldering is fun! |
