2013 nissan sentra, non smart key or pts
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137951
Printed Date: May 04, 2024 at 5:49 AM
Topic: 2013 nissan sentra, non smart key or pts
Posted By: jgarcia1925
Subject: 2013 nissan sentra, non smart key or pts
Date Posted: December 12, 2014 at 2:58 PM
hello, ill be using a CA6554 with flashlogic FLCAN for immobilizer
i have seen on a few other sites that some people have been having issues with the 2013 sentra throwing CEL on. has anyone had this issue?
i see that this car does not have second start, only 2nd acc... now, has anyone on here had this issue with any remote starts? if so what can i do to get around it?
Posted By: chev104275
Date Posted: December 12, 2014 at 6:05 PM
Could be a timing issue making sure the connections are setup correctly (ing as ing and acc as acc)
12 VOLT CONSTANT GREEN (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 3
STARTER BLUE (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 2
IGNITION 1 RED (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 1
ACCESSORY /HEATER BLOWER 1 PINK (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 4
ACCESSORY /HEATER BLOWER 2 WHITE (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 5
------------- If i Can't Install it I Don't need it Joe
Posted By: tedmond
Date Posted: December 12, 2014 at 11:34 PM
isolate your start wire with a diode inline
------------- Ted
Compustar Expert
Date Posted: December 13, 2014 at 9:38 AM
Some people have said that. Do you think a 3 amp will be suffice? Or do I need anything more than that?
Posted By: tedmond
Date Posted: December 13, 2014 at 9:01 PM
i would use 6amp to be safe
------------- Ted
Compustar Expert
Date Posted: December 13, 2014 at 9:24 PM
Cool. All I have is 3amp. Might have to run somewhere to get one then thanks
Posted By: tedmond
Date Posted: December 13, 2014 at 11:44 PM
doesnt hurt to use 3 amp to see if that helps rid of the CEL issue. if the issue is resolved go purchase 6amps
------------- Ted
Compustar Expert
Posted By: Chris Luongo
Date Posted: December 14, 2014 at 9:11 AM
I would just put two of the 3-amps in parallel.
