remote starter keeps restarting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138294
Printed Date: May 08, 2024 at 1:42 AM
Topic: remote starter keeps restarting
Posted By: rjkboyle
Subject: remote starter keeps restarting
Date Posted: January 18, 2015 at 3:36 PM
Details:
2005 Acura TSX w/NAV
Viper 5806v
XK09 Bypass - 9.DLPKHO v1.12 firmware
Wired D2D, no tach wire hard wired to the car.
When remote starting the car will run for 1-5 min (always different amount of time) then shut off. The remote start will then turn on again and fire the car up. It will continuing running for a few minutes, then shut off. Wash rinse repeat.
I have the remote starter programmed to Virtual Tach mode. Tried the other programming modes, but they either didn't start the car, or did the same thing.
Really hoping someone has seen this before and can tell me how to fix it?
Posted By: tedmond
Date Posted: January 18, 2015 at 4:00 PM
the problem is the virtual tach. Virtual tach works by registering change in voltage, but honda has a voltage controller on the alternator causing virtual to work poorly on all honda vehicles.
You should program change it to the tach setting, then you must program the tach. your problem will be solved.
------------- Ted
Compustar Expert
Posted By: rjkboyle
Date Posted: January 18, 2015 at 4:02 PM
Thanks Ted
Always saving me man!
