ignition t harness build or buy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138342
Printed Date: May 01, 2024 at 7:04 AM
Topic: ignition t harness build or buy
Posted By: jonhimes
Subject: ignition t harness build or buy
Date Posted: January 26, 2015 at 3:51 AM
I have a 2008 Toyota Camry LE 4Door 2.4 automatic std key start.
I am going to install an Autopage C3-RS1100 OLED
Using an ADS-ALCA with USB programming cable
I am looking for an ignition harness. I found a Metra AX-ONE-TTOY2 and I know bulldog makes one. The problem is I only found one retailer for the Metra and there is not much info on the company selling it and the Bulldog is pretty poorly rated.
I am an electrical engineer and am great with iron so it is more about maintaining the integrity of the ignition system itself.
Can someone tell me places to find the AX-ONE-TTOY2 and tell me if it is any good.
Second does anyone know the manufacturer of the Toyota connectors(doesn't really look like Molex so I don't know) so that I may build my own custom T Harness.
Also if anyone had done an install with some or all of the items above any input would be appreciated.
Posted By: jonhimes
Date Posted: January 26, 2015 at 3:58 AM
Also I forgot to mention this is 6 speaker standard as well not the JBL. I am installing:
Autopage C3-RS1100 security system
Dashcam
Backup rearview cam
4 pioneer 6x9 speakers
1 zenclosure 12 in Rockford Fosgate
1 MB Quart Onyx 1100.5
1 set low beam HID conversion
1 optima battery
1 set of fog lights
Fatmat on doors floor head liner rear deck
cold air intack
so I will have full reign of the car since I will be doing everything "at once"
hope that helps
Posted By: auto enhancers
Date Posted: January 26, 2015 at 11:36 AM
that harness is to plug into the evo-one not just a generic t harness. I would assume you could make it work for your application with a few modifications.
Posted By: tedmond
Date Posted: January 26, 2015 at 2:59 PM
strip, poke and twist, solder. no point in making a t harness. wasted effort in my opinion.
------------- Ted
Compustar Expert
Posted By: jonhimes
Date Posted: January 27, 2015 at 9:29 PM
Ok Thanks. We'll see how it goes this weekend
Posted By: shark mobile
Date Posted: January 27, 2015 at 10:57 PM
I'm with Ted on this one...Camry is an easy one...very straight forward install. Have fun with it! Cheers
------------- Solder, tape, repeat!
