2014 dodge journey ignition +
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138363
Printed Date: April 29, 2024 at 11:48 AM
Topic: 2014 dodge journey ignition +
Posted By: Komobu
Subject: 2014 dodge journey ignition +
Date Posted: January 28, 2015 at 2:38 PM
Hi;
I am trying to install a Fortin evo-all with the Chry6 T-harness. This vehicle has Push to Start. I have found everything except the Ignition + wire. The fortin manual says it is in the drivers kick panel. I see a harness with about 100 wires in it. I even found a pink wire w/ white stripe. It is not 12v though with the car running, it is a ground.
Any pics or better instructions where this wire can be found?
Is it possible to hook it to any wire that is 12v with Key On like an injector?
Thanks for any help
Posted By: tedmond
Date Posted: January 28, 2015 at 4:25 PM
the voltage is not 12v on that line. it will be ranging from 5-9v, and only hot when the key is in the ignition.
------------- Ted
Compustar Expert
Posted By: Komobu
Date Posted: January 28, 2015 at 4:52 PM
Thanks for the help, but are you sure? I found a Pink wire with white stripe in the main harness of the drivers kick panel. It is 0v key off and about 13 while running. The install instructions I am using are here: https://fortin.ca/en/download/12181/
If you are sure it is 5 to 9 volts, it sounds like it wants reference voltage that could be taken from any sensor ie tps, map or the like. Any idea why it would want reference voltage?
Posted By: tedmond
Date Posted: January 28, 2015 at 4:55 PM
5-9 is normal when youre just testing the line with a door open. During actual start and run then the voltage increases to 13-14.4
------------- Ted
Compustar Expert
