Viper 4205, 93 Dodge Spirit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138374
Printed Date: April 29, 2024 at 12:21 PM
Topic: Viper 4205, 93 Dodge Spirit
Posted By: hawkeye
Subject: Viper 4205, 93 Dodge Spirit
Date Posted: January 29, 2015 at 8:13 PM
Hello
I am having an issue with getting my remote start to program I cannot get the led light on the brain to power on when I press the valet button. my car is a 93 dodge spirit
Here is my setup im not sure if im missing something
H1/1 LIGHT GREEN/ not connect
BLACK FACTORY ALARM DISARM not connected
H1/2 GREEN / WHITE FACTORY REARM not connected
H1/3 YELLOW (+) IGNITION OUT (TO ALARM) not connected
H1/4 WHITE/ BLUE (-) ACTIVATION INPUT not connected
H1/5 ORANGE (-) GROUND WHEN LOCKED* not connected
H1/6 BROWN (-) HORN OUTPUT connected
H1/7 RED / WHITE (-) TRUNK RELEASE OUTPUT* not connected
H1/8 BLACK GROUND connected
H1/9 WHITE (+/-) LIGHT FLASH Not connected
4-pin satellite harness wiring daigram
1 BLUE STATUS OUTPUT Not connected
2 ORANGE (-) ACCESSORY OUTPUT not connected
3 PURPLE (-) STARTER OUTPUT not connected
4 PINK (-) STARTER OUTPUT not connected
Heavy gauge relay wiring diagram
1 PINK (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT connected
2 PURPLE (+) (30 AMP) OUTPUT TO STARTER CIRCUIT connected
3 ORANGE (+) (30 AMP) OUTPUT TO ACCESSORY CIRCUIT Not connected yet
4 RED (+) (30A) HIGH CURRENT 12 INPUT
5 PINK/WHITE (+) PROGRAMMABLE OUTPUT FOR ACCESSORY OR IGNITION not connected
6 RED (+) (30A) HIGH CURRENT 12V INPUT connected
Door lock harness, 3-pin connector
1 BLUE (-) UNLOCK OUTPUT Not connected
2 EMPTY NOT USED
3 GREEN (-) LOCK OUTPUT Not connected
Remote start harness (H2) wiring diagram
H2/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT connected to ground
H2/2 VIOLET/WHITE TACHOMETER INPUT WIRE connected
H2/3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE connected
H2/4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE not connected yet
H2/5 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT not connected
Connected
Posted By: tedmond
Date Posted: January 29, 2015 at 8:29 PM
what are you trying to program exactly ? Since its a remote start i will assume tach programming?
------------- Ted
Compustar Expert
Posted By: hawkeye
Date Posted: January 29, 2015 at 9:55 PM
I am trying to program the remotes so they start the vehicle. I'm not sure why its not working. The led in the module doesn't come when i press the valet button and run through the remote program, so I am not sure what I am doing wrong.
Posted By: hawkeye
Date Posted: January 29, 2015 at 10:32 PM
Also this is my first install of a remote start so I am just wondering if I have something thats not connected that needs to be?
Posted By: tedmond
Date Posted: January 29, 2015 at 10:54 PM
double check your ignition to ensure it is infact an ignition wire.
------------- Ted
Compustar Expert
Posted By: hawkeye
Date Posted: January 29, 2015 at 11:09 PM
Ok will do! also on primary harness there was a 12v wire on the older style harness where as this I dont see one should there be 12v connected to this harness? also is the yellow wire of this just another ignition wire that doesnt need to be hooked up?
Primary Harness (H1), 9-pin connector
H1/1 LIGHT GREEN BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT
H1/2 GREEN / WHITE (-) 200mA FACTORY ALARM REARM OUTPUT
H1/5 ORANGE (-) 500mA GROUND WHEN LOCKED/ANTI-GRIND OUTPUT
H1/6 BROWN (-) 200mA HORN OUTPUT
H1/7 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT*
H1/8 BLACK GROUND INPUT
H1/9 WHITE (+/-) LIGHT FLASH OUTPUT
Posted By: hawkeye
Date Posted: January 30, 2015 at 10:21 PM
Ok, I checked the ignition and I am getting 12v at the pink wire of the harness with key turned to the last click. I also checked the starter (12v) when started and both the high current 12v inputs. all check out good. I have a good ground as well.
Is there something I am missing?
Posted By: tedmond
Date Posted: January 30, 2015 at 11:33 PM
make sure the wire does not loose 12v when starting.
------------- Ted
Compustar Expert
Posted By: banthonyb71
Date Posted: February 01, 2015 at 1:02 AM
What is your process of programming? are you turning the ignition on, tapping the valet button once then pressing and holding?
Posted By: hawkeye
Date Posted: February 02, 2015 at 12:23 PM
Turns out it was a defective module. It was a refurb and was defective out of the box. I got a brand new one on the exchange and it works like it should.
Thanks for your help guys!
Posted By: hawkeye
Date Posted: February 06, 2015 at 2:57 PM
Does anybody know what the correct wire for accessory would be on a 93 dodge spirit? I checked ready remotes web site and it says its black, but the black wire in the ignition harness is ground.
Posted By: tedmond
Date Posted: February 06, 2015 at 4:46 PM
BLACK/ Orange (+)
------------- Ted
Compustar Expert
Posted By: hawkeye
Date Posted: February 06, 2015 at 11:58 PM
awesome! Thank You!
