2002 Camry, Prostart 3471
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138432
Printed Date: May 28, 2024 at 11:47 PM
Topic: 2002 Camry, Prostart 3471
Posted By: redrock1
Subject: 2002 Camry, Prostart 3471
Date Posted: February 06, 2015 at 6:48 PM
Using a prostart 3471 on a 2002 Camry standard trams need to know what wire from the autostart unit I use and which wire to connect to at the clutch
Posted By: tedmond
Date Posted: February 06, 2015 at 8:36 PM
Clutch - BLACK/ White (+). Connect your purple start wire directly to this wire.
------------- Ted
Compustar Expert
Posted By: redrock1
Date Posted: February 07, 2015 at 12:26 PM
2002 camry with std trans , prostart unit , where is the best and most simple location to attach the orange park break input - from the start unit to the hand brake
Posted By: redrock1
Date Posted: February 07, 2015 at 4:03 PM
Door lock issue one wire diagram says use lite green to lock and red green to unlock , car. Has child safety wire? Other says use blue and blue white , confused as it says car has child safety door lock diagram
Posted By: tedmond
Date Posted: February 07, 2015 at 6:25 PM
parking brake - RED / White (-) @ fuse box in white 24 pin plug
blue and blue / YELLOW (-) @ driver kick panel in blue plug for lock, white plug for unlock
------------- Ted
Compustar Expert
Posted By: redrock1
Date Posted: February 07, 2015 at 8:42 PM
The wires at the clutch are WHITE/ blue and RED / blue ,the red blue is 12 volt all time and the white blue is 12 volt and 0 when you start to press clutch , there is no black white wire
Posted By: redrock1
Date Posted: February 07, 2015 at 9:31 PM
Park brake ,red white in 24 pin white connector. I do not have a red white wire in the 24 pin connector
Posted By: tedmond
Date Posted: February 07, 2015 at 11:05 PM
you're looking at the wrong clutch connector. One is for cruise control, the other is for starting.
I had this vehicle and its the parking brake wire is definitely there.
------------- Ted
Compustar Expert
