viper smartstart + 4806v, 2000 Dodge Dakota
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138455
Printed Date: May 30, 2024 at 1:52 AM
Topic: viper smartstart + 4806v, 2000 Dodge Dakota
Posted By: jsigna
Subject: viper smartstart + 4806v, 2000 Dodge Dakota
Date Posted: February 09, 2015 at 4:23 PM
Hey guys I am going to be installing a VSM200 into a 2000 Dodge Dakota (black key/no antitheft) with a Viper 4806v Remote Start/Keyless Entry system.
My confusion starts the 3 plug option. It looks like the Black pin is used for bitwriter and that leaves me with the Brown ESP and D2D wire.
Now this remote start I wired a while back has no bypass module so the D2D is definitely free to use. However I am seeing conflicting information on which to use.. D2D or Brown ESP plug into my 4806v.
Second questions is on the on the 5 pin cable. It says that the analog output wires are only active if the device has been configured for Analog Wire mode in the installation portal.
Final question is on the Configuration Wires. I see ESP2, D2D/RSR/RXT, and AutoStart/AstroStart.
What configuration method should I use? I suppose it depends on the plug I use.
Any help would be amazing. Thanks!
Posted By: jsigna
Date Posted: February 09, 2015 at 7:46 PM
I assume the 5 wire harness is for s hard wire? I know some of you guys have installed this before.
Posted By: auto enhancers
Date Posted: February 12, 2015 at 10:05 AM
dont use the 5 pin harness, use the esp plug and connect power and ground,
Posted By: jsigna
Date Posted: February 15, 2015 at 11:33 AM
Thanks! I actually did just that.. Black plug.. Workes great!
Really looking forward to the Viper Smart Start 4.0 app.
