2004 Mustang GT installing Python 533
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138632
Printed Date: May 12, 2024 at 1:37 PM
Topic: 2004 Mustang GT installing Python 533
Posted By: waynetx383
Subject: 2004 Mustang GT installing Python 533
Date Posted: March 09, 2015 at 11:05 PM
I am in the process of prepping everything to install a Python 533 into my Mustang and had a couple of questions before the installation.
From the wiring diagrams I've found on here and bulldog it appears there are two ignition and two accessory wires. The alarm unit has a selectable output for a second ignition or accessory circuit. I'll need to use a relay setup to power the other ignition or accessory circuit that is not included, correct?
Would that be the purpose of one of these:
PINK/WHITE (-) 200mA PROGRAMMABLE IGN2/ACC2 RELAY TURN ON
YELLOW (+) IGNITION INPUT TO ALARM
PINK (-) 200mA IGNITION RELAY TURN ON
ORANGE (-) 200mA ACCESSORY RELAY TURN ON
PURPLE (-) 200mA STARTER RELAY TURN ON
ORANGE / BLACK (-) ANTIGRIND/GROUND WHEN ARMED OUTPUT
BLUE (-) 200 mA STATUS OUTPUT
There are also both a + and - parking light wire listed in the diagram. The unit has an output that is selectable to + or -. Do I need to tie into both the wires in the car, or just one or the other?
Posted By: howie ll
Date Posted: March 10, 2015 at 3:58 AM
Use the selectable output for second ignition then relay the orange 200mA output.
Don't know the vehicle but I'd use the Pythons NEG output.
