VW Golf Mk3 Vacuum System replacement
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138649
Printed Date: May 15, 2024 at 9:01 PM
Topic: VW Golf Mk3 Vacuum System replacement
Posted By: chassis
Subject: VW Golf Mk3 Vacuum System replacement
Date Posted: March 12, 2015 at 12:04 PM
Good day! Is it possible to replace the vacuum system with aftermarket actuator on this vehicle.the front door locks looks a lil funny for me.I have done it on other vehicles and it was quite easy.this one looks like a mission.
------------- Do it once,do it right - This means no short cuts. You never get paid twice for having to do the job twice because it wasn't done right the first time.
Posted By: howie ll
Date Posted: March 12, 2015 at 2:17 PM
Yes but you'll also have to do the tailgate and fuel flap.
The door has a metal insert rather than a splash shield everything is behind it, window motor mech. and glass, all has to come out.
Frankly it's easier and cheaper to replace or repair the vac system.
Usually a pipe's come unstuck, mostly after bodywork, listen for the hiss.
Posted By: chassis
Date Posted: March 15, 2015 at 7:35 AM
Thank you Howie!I think I will rather look for the problem and fix it.
