viper 5904, ignition switch recall
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138684
Printed Date: May 03, 2024 at 10:48 PM
Topic: viper 5904, ignition switch recall
Posted By: quebert
Subject: viper 5904, ignition switch recall
Date Posted: March 18, 2015 at 2:44 PM
Tomorrow I'm suppose to take my car to the dealer to get the ignition recall fixed. The lady told me I needed to bring all the key's in so they can re-program them. Until last night I didn't even think about my alarm. I seem to remember the shop that installed my alarm needing a key. I don't want to wait to get the recall fixed it's important, but I don't want to not be able to drive my car home.
My question is what exactly needs to be done here? I'd like to fix it myself if I could.
Posted By: tedmond
Date Posted: March 18, 2015 at 4:35 PM
when you say ignition recall, I assume its a GM?
What year and make is the vehicle? Btw when they do the ignition recall, they issue you new keys. I have yet to see one that had the tumbler rekeyed.
------------- Ted
Compustar Expert
Posted By: quebert
Date Posted: March 18, 2015 at 5:05 PM
Sorry, it's a 2008 Saturn Sky Redline, when I said they were going to re-program my keys I was just assuming. New keys makes more sense though for sure. Which still leaves me with my initial alarm question. What will I need to have done to make my car drive-able after they replace the ignition? I definitely remember having to have a give the stereo shop a key before they installed my alarm. I don't remember if they gave it back though, so maybe it's something I can do myself like when I programmed the 2nd FOB? I'll probably call GM today and put off the servicing until someone here can clue me in on what I'll need to do alarm wise.
Posted By: pentavolvo
Date Posted: March 18, 2015 at 5:25 PM
Odds are on a gm you got the key back which means your bypass will need to be reprogrammed after they change the key. The dealer won't do this
If they did a key in the box you need to get the key out of the box, hand it in, then take the new key and put back in box
Posted By: tedmond
Date Posted: March 18, 2015 at 7:50 PM
There was a bypass available in 08, so most likely it was a data style bypass. These cars came with 2 master keys. If you only have one, the other might be put in a key-in-box. Either way it doesn't hurt to peek under the dash. A simple reprogram will do it.
Take a picture or post what you see.
------------- Ted
Compustar Expert
Posted By: quebert
Date Posted: March 18, 2015 at 10:02 PM
I bought the car used and it only came with 1 key, I had another made but I only have 1 master key. I'm not an expert on alarms, I get what you're saying about the bypass needing to be reprogrammed. But I Googled and didn't see any directions. It sounds like it could be something I could do. When I get out of work I will search under my dash for this box. I'm guessing since I only have 1 master key GM will only give me 1, I guess I'll find out.
Posted By: howie ll
Date Posted: March 19, 2015 at 1:30 AM
Is an alarm or alarm plus remote start installed?
Posted By: quebert
Date Posted: March 19, 2015 at 1:31 AM
It's remote start too, forgot to mention that which probably make a difference here.
Posted By: howie ll
Date Posted: March 19, 2015 at 1:37 AM
OK, if they didn't use a data by-pass there will be a black box under/inside dash about the size of a cigarette pack. Possibly marked DEI 456. Need to change for new or re-programmed key.
If data the data unit needs to reprogrammed.
