Connect aftermarket alarm to central door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138727
Printed Date: April 29, 2024 at 12:31 AM
Topic: Connect aftermarket alarm to central door locks
Posted By: joakimahl93
Subject: Connect aftermarket alarm to central door locks
Date Posted: March 25, 2015 at 12:35 PM
Hello!
Ive got a aftermarket alarm kit and an aftermarket central door lock kit laying around and i thought i would put it in my car, but i dont really want to have 2 keys i need to press each time to unlock and shut off alarm...
So im guessing theres a way to connect the 2 kits so i can use them with one key, i suck at this so i gotta ask you guys!
Heres the instructions for the two kits, the central lock kit doesnt say much i guess but thats all that came with it
Date Posted: March 25, 2015 at 12:36 PM
Im not sure why i cant see the second photo i added but heres the picture web adress! :)
https://www.volkswagengolf.se/album_pic.php?pic_id=31610
Posted By: tedmond
Date Posted: March 25, 2015 at 1:02 PM
what vehicle?
------------- Ted
Compustar Expert
Posted By: smokeman1
Date Posted: March 25, 2015 at 1:09 PM
Does you car already have power locks? or are you adding the actuators?
------------- When all else fails, Read the Instructions
Posted By: howie ll
Date Posted: March 25, 2015 at 1:22 PM
Re Ted's comment, there are about 12 ways to control central locking. Assuming an existing system, vehicle make, model and year please.
Date Posted: March 25, 2015 at 1:25 PM
oh im sorry!
The vehicle is a vw golf mk1 1983
so it does not have alarm or central door lock or anything from the beginning!
Date Posted: March 25, 2015 at 1:48 PM
It looks like to me, from your alarm
Orange & Orange /Black to ground
Yellow & Yellow/Black to 12 volts constant
White to White on Central Door Lock Kit
WHITE/ Black to Brown on Central Door Lock Kit
Central Door Lock Kit needs 12 volts constant and Ground.
If system locks when it should unlock, reverse the White and WHITE/ Black connections on the White and Brown wires.
How about it Howie or Ted
Posted By: tedmond
Date Posted: March 25, 2015 at 3:11 PM
looking at the diagram of the keyless unit, i believe it's:
orange & ORANGE / black - 87a
white & WHITE/ black - 30
yellow & yellow/black - 87
so you would need to ground yellow & yellow/black, snip and do not use ORANGE / orange black. The white and WHITE/ black will go to your actuator kit (brown and white)
------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: March 25, 2015 at 3:16 PM
Wired as diagram two or get a complete motor kit from the leading Italians, SAL or MES includes timer relay and driver door lock control, then wire as per diagram 1.
Posted By: tedmond
Date Posted: March 25, 2015 at 3:34 PM
Howie, he does have an actuator kit in post 2. Had to visit the website.
------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: March 25, 2015 at 4:26 PM
Sorry,doing this during add breaks.
Then figure two if no relay with the kit.
Date Posted: March 26, 2015 at 3:23 PM
Thanks guys! will try this when i get some time for it!
Btw, is there any way to connect this so the blinkers flash also?
would be nice to have that also :)
Posted By: howie ll
Date Posted: March 26, 2015 at 5:08 PM
Brown wires, BLACK/ green and BLACK/ white, steering column loom, take car and test.
