Directed 535T in 2014 Ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138738
Printed Date: April 30, 2024 at 3:32 AM
Topic: Directed 535T in 2014 Ram
Posted By: jimd2p
Subject: Directed 535T in 2014 Ram
Date Posted: March 27, 2015 at 10:39 PM
I am trying to install a Directed 535T in a 2014 Ram 1500 Express. It's a 2 door, with factory express down. It will be triggered by a Viper 4706V remote start. I am having difficulty with this because it appears to have a door module for each door and be a CANBUS system. Just don't want to screw something in the system. I plan to trigger them down with the orange wire from the Viper remote start, but also need help knowing which wire to use to trigger them up. Any help would be appreciated.
Posted By: howie ll
Date Posted: March 28, 2015 at 5:46 AM
Orange from Viper is constant triggered UP.
Use one of the aux wires for down.
Wire directly to the motors in each door.
Most modern cars run data from a body control to the door module which then converts the data to standard motor wiring, NEG at rest the one side goes POS on actuation.
Posted By: howie ll
Date Posted: March 28, 2015 at 5:48 AM
BTW, sorry from switch to body control to door module. And it's CAN and LIN in the door.
My driver door switch panel has 4 X one touch up down window switches plus mirror, 4 wires coming from the plug.
Posted By: jimd2p
Date Posted: March 29, 2015 at 8:11 PM
Thanks Howie. So would I, in each door, run the wires so that one side of the module goes to the switch and the other to the motor, essentially bypassing the door control modules?
Posted By: howie ll
Date Posted: March 30, 2015 at 1:47 AM
Yes go directly to motors.
