Hey guys, I'm going to be installing a Viper 5706V remote start with alarm in my car, and I will be using the Expresskit DBALL2. I want to make sure I have all the connections I need figured out...
VIPER CONNECTIONS
H1/1 (+)12V CONSTANT INPUT (+)12V CONSTANT
H1/2 (-) CHASSIS GROUND GROUND TO CHASSIS
H1/3 (+) SIREN OUTPUT HOOK TO (+) SIREN
H1/4 PARKING LIGHT ISOLATION N/A
H1/5 PARKING LIGHT OUTPUT N/A
H1/6 (-)500 mA GROUND WHEN ARMED N/A
H2/1 FLEX RELAY CONTROL OUTPUT N/A
H2/2 (-) NEUTRAL SAFETY INPUT GROUND TO CHASSIS
H2/3 (-) 2ND STATUS/REAR DEFOGGER N/A
H2/4 (-) OEM ALARM DISARM N/A
H2/5 (-) TRUNK RELEASE OUTPUT N/A
H2/6 (-) DOOR TRIGGER INPUT GREEN N/A
H2/7 (-) DOME LIGHT SUPERVISION OUT N/A
H2/8 (-) HORN HONK OUTPUT N/A
H2/9 (-) STATUS OUTPUT N/A
H2/10 (-) IGNITION 1 OUTPUT N/A
H2/11 (-) AUX 3 OUTPUT N/A
H2/12 (+) DOOR TRIGGER INPUT N/A
H2/13 (-) AUX 1 OUTPUT N/A
H2/14 (-) AUX 2 OUTPUT N/A
H2/15 (-) AUX 4 OUTPUT N/A
H2/16 (+) BRAKE SHUTDOWN INPUT BRAKE SWITCH
H2/17 (-) HOOD PIN INPUT TO HOOD PIN
H2/18 (-) STARTER OUTPUT N/A
H2/19 (-) TRUNK PIN/INSTANT TRIGGER N/A
H2/20 (-) DIESEL WAIT TO START INPUT N/A
H2/21 (-) REMOTE START/TURBO TIMER N/A
H2/22 (-)200mA ACCESSORY OUTPUT N/A
H2/23 TACHOMETER INPUT N/A
H2/24 (-) OEM ALARM ARM OUTPUT N/A
H3/1 IGNITION 1 INPUT/OUTPUT PINK IGNITION WIRE
H3/2 FLEX RLAY (+)12V INPUT (FUSED) 12V CONSTANT
H3/3 ACCESSORY OUTPUTN/A
H3/4 STARTER OUTPUT N/A
H3/5 STARTER INPUT N/A
H3/6 IGNITION 1 (+)12V INPUT(FUSED) 12V CONSTANT
H3/7 FLEX RELAY OUTPUT IGNITION WIRE
H3/8 FLEX RELAY INPUTN/A
H3/9 ACCESSORY/STARTER RELAY(FUSED) 12V CONSTANT
H3/10 EMPTY
NO PINS ON DOOR LOCK HARNESS USED
DBALL2 CONNECTIONS
12/1 RAP OFF TO DRIVER DOOR SENSE TRIGGER
12/3 DOOR STATUS OUTPUT N/A
12/4 TRUNK STATUS OUTPUT N/A
12/5 TACH OUTPUT N/A
12/6 BRAKE STATUS OUTPUT N/A
12/7 ACCESSORY OUTPUT TO ACCESSORY WIRE
14/1 SINGLE WIRE CAN TO PIN 1 ON OBD PORT
14/10 IMMO CONSTANT (CAR SIDE) TO CAR SIDE OF IMMOBILIZER WIRE
14/11 IMMO CONSTANT (CONN. SIDE) TO CONNECTOR SIDE OF IMMO. WIRE
14/13 (+)12V N/A
14/14 (-)GROUND N/A
CONNECTOR 10 NOT USED AT ALL.
CONNECTOR 4 HAS D2D CABLE, CONNECTED TO D2D PORT ON VIPER.
Use D2D follow the DBALL2 install guide this car is easy. You wont have to hard wire the brake wire the DBALL2 takes care of that for you. You only have to do it on some Saturns. You can get 12v constant at the BCM. Only other wires you have to hook up from the 5706 are ignition, ground, hood pin and parking lights. The DBALL2 takes care of all other connections.
Forgot you will also have to ground the neutral safety wire on the brain.
Dairyboy sorry to be a pain but don't forget the siren
