Most important sensors to add to factory car alm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138941
Printed Date: April 28, 2024 at 2:58 PM
Topic: Most important sensors to add to factory car alm
Posted By: cz eddie
Subject: Most important sensors to add to factory car alm
Date Posted: May 07, 2015 at 7:45 PM
So for various reasons, I've decided to retain my factory car alarm on my 2015 Kia Optima with smart key. Now I need to focus on beefing up this alarm. As far as I know, it simply monitors the doors/trunk. Opening one of these up while alarmed will set the car horn beeping and disable the ignition.
I'm thinking of adding the following to the door trigger so that when one is set off, it will fool the alarm into thinking the door has been opened and set off the alarm.
1) Window breakage sensor.
2) Tow sensor.
3) Interior movement sensor (I tend to leave windows open).
Am I missing anything really important?
Is there a quality difference between the various sensors I might find on Amazon Prime?
Posted By: howie ll
Date Posted: May 08, 2015 at 6:56 AM
Interior movement sensor.
I''m not sure but you may have compatibility problems adding ANY aftermarket sensor.
