Dlpkgm and VSM250 compatibility
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139465
Printed Date: May 30, 2024 at 10:49 AM
Topic: Dlpkgm and VSM250 compatibility
Posted By: kawijess
Subject: Dlpkgm and VSM250 compatibility
Date Posted: September 23, 2015 at 9:40 AM
Hi, is the VSM250 and the Dlpkgm compatible? I had the VSM200 before which worked perfectly and upgraded to 250, but am not able to get a solid green light, and can't program the Dlpkgm. I have the 5901.
Per the instructions, it says to ground the grey wire if using D2D. Can the grey be grounded to the black wire that is used to power the vsm250?
When I first connect everything I get a a solid Amber and green light. When I try and program the Dlpkgm, the green light turns off on the 250 and I'm unable to program the Dlpkgm. The remote start nor the door locks work. If I don't plug in the 250, I'm able to program the Dlpkgm and the RS and door locks work.
I hope this is clear. Thanks for your time!
